had a housemate decide to take up Heroin and shoot up and die.
another obsessied with porn, he has a tv with a video, dvd and VCD attached hit play on any porn played.
(oh and his remotes were all in plastic baggies.)
asorted vego's ppl who late on rent, very loud sex, blah blah blah
^lol
My most interesting was late 30's dude with short term memory loss. He didn't work and ended up relapsing to weed but place was a pad. Out door spa with thatch roof, pool table etc. He was a nutcase.
Alex you f**k answer my question.
What suburbs you cover?
Am stomping around coburg looking for a place.
Got hookups? Insider knowledge?
<3
Sorry man iPhone doesn't show all posts so didn't see it!
I do west man if there's a certain house you want info on just pm me or message me on fb I can get some info on pretty much any house!
  • Like 1
Loud sex. Like your number plate lol
  • Like 3
Many different avenues. Depends on circumstance but have full RP data access for dat dere "free" info
Rp is shite we don't disclose sales to rpdata so their info is out dated bad not only us almost everyone in our market refuses to disclose
I'd say it's probably 1 in 20 that is not disclosed, if that. It has a lot of free info that i then take to other systems to cut costs and make life quicker. I love it.
Yeah in most areas it's probably fine particularly auction areas as its all disclosed same day/ next day generally. Private sale not so much
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
