Edit
I went to a bank auction for a house. Got passed in & went in to negotiate as I was only bidder.
Realestate didn't want to drop from reserve price, has now listed as private sale for $50k more than reserve price.
I don't understand that logic.
Bank probably getting shafted in all of this.
which ones?
Audio-Technica ANC9's
http://www.scorptec.com.au/product/Headphones/Wired/46443-ATH-ANC9
They work as advertised, fine when listening to music, plenty of range (and bass if the song requires it), comfortable on my head, quality build, replaceable ear padding foam bits, can disconnect the cable at the headphone itself if you want just the noise cancelling, single AAA battery (have been through a 6 pack of Varta AAA's (cheap low capacity crap) so far, will get some rechargable energiser AAA's I think, I keep leaving the switch on when I go home from work)
However, I've never been able to deal with the white noise generated by Noise Cancelling Headphones, if its not perfect it makes a slight noise which makes me a bit queezy after a while. So even on a plane, I need to have some sort of music playing, then it doesn't effect me.
So every bacon sandwitch knocks off half an hour of your life.
Struggling to believe alot of what is written in the article
When you consider how third hand the information is, there is no reason you should believe it. Even research supported articles can be total bullshit, taking shady research findings out of context or misquoting or contradicting.
We live in an age where we've never had easier and greater access to information...an unfortunate byproduct of that is our exposure to equally large quantities of bullshit.
Neg.
When selling on behalf of bank agent has zero control the regs on bank sales are super tight
How did you know it was a bank auction?
Yeah the only nutrition advice I read atm is from Alan Aragon and Layne Norton
I don't even take nutrion advice from experts, rather just experiment with my own body and go from there...everyone is different so half the stuff they say doesn't work for everyone anyway.
  • Like 1
this.
my favourite part of the article: it used to be ok to drink 6 cups or coffee/tea a day.
its true though that recent studies have shown sugar to have a larger affect on general unhealthiness than fats. and ive always preached brown/black bread is the only way to go. f**k those white loaves. #breadracism
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
