so it's time to get the S14 back on track.
got car started and moving today,
found a animal nest and crap under bonnet, excuse to by a kartcher and blasted that shit clean.
so I went over al the wires and hoses checking they had not been chewed.
and I found 1 split hose.
pulled the host off to find that in the plastic tee that the host plugged into had a screw in the end jaming it off with the ose covering it.
from the pic below it is the hose that is listed as "to turbo"
I cannot work out where that hose ends up, does it need to be blocked off or can I just cut and tuck it?
sorry to ask a car question in here but you never know some-one might have an answer.
is there time to change before bus leaves/at airport/at camp?
Nop new policy in place. Bus departs straight from office to airport.
Gain an additional hour of productivity as no work time wasted on changing at camp.
nope high viz clothing is allowed as it deemed a uniform.
which is funny
as the complaints were from the suits about the high vis clothing in the lounges.
I seriously don't see an issue about it, it's somewhere to kill an hour prior to a flight that they happen to have some free snacks and booze,
who cares what people wear.
They hate us because they anus
Hi-vis for lyf
lounge has says they will let you use showers and get changed is not correct on arrival.
  • Like 1
Boost solenoid connected to post afm intake pipe and wastegate actuator. I'd imagine the other end is likely connected to a nipple on the turbo outlet. Am assuming you're running the stock solenoid setup? I could be wong as I have nfi about SR's
It's like S13's and R32 GTST's though. Used to be everywhere now (Especially 32's) see maybe one every 6 months. Tipping Silver 34 GT/GTT's will be the next endangered species.
Edit: Related
398612_2256171378623_907531797_n.jpg?oh=
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
