Today is gonna be best day of air show imo cos the b52 stratofortress is only doin a fly over today not any other day real shame cos it's a huge ass mofocker
Who's idea was it to schedule that on a day that everyone is at work and school?
Unless they're also doing a flyover the city to get people looking to the skies and interesting in coming on Saturday / Sunday...
Nothing says "Marketing Genius" like making people think the Rialto is about to be attacked by a flying fortress
I remember a few years ago it was supposed to do a fly-over of St Kilda yacht club area from Point Cook. few hundred people rocked up to the wave break pier thing and waited for like 2 hours. finally a tweet spread that they couldnt get it ready in time...
wasn't that the AC130 Spectre
  • Like 1
I was going to go to that... glad i am lazy
Simon, any I.T jobs going at your work? :P
Nope... It's just me atm... I fired my lackey a few months ago because he was useless and there probably wasn't enough work for both of us (though I was down to 50% efficiency because I had to hand hold so much).
Now my workload is high, but not high enough for another person to come onboard...
Ahh fair enough, well if that changes let me know :P
Getting f**k all opportunities at my current place.
Well there's one static display and the one doing the flyover today is flying 16 hours straight to participate and keeping on going no stops.
Decent range... probably $100k worth of fuel :P inb4 scotty suggests E85
  • Like 1
they already did it
http://www.airforce-technology.com/features/featureflying-fuel-efficient/featureflying-fuel-efficient-6.html
edit:
oh and it holds 181,610 L of fuel..
enough to get it 1600km
if it flying 16 hours will need at least one refuel.
so 300,000 Litres plus the fuel from the refueling aircraft.
guessing they pay more than 1$ a liter for aircraft fuel..so think 500K -1 Mill
or to put it in VWL terms, one house sold dogily to someone fronting a Chinese millionaire.
  • Like 1
You were in a 4G inverted dive with a mig 28?
I flew with your old man. VF-51, the Oriskany. You're a lot like he was. Only better...and worse. He was a natural heroic son of a bitch that one.
thats the one
shiiiieeeet
buying suspension arms... f**king arms for everything. pulsar is like an amputee that can do -6 degrees camber. no arms needed.
any opinions on SRI arms from Just Jap? look cheap-ish but i aint racing the thing
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
