What did liberal get right today? I'll tell Ya!
Abbott is spot on about not funding remote communities they have no right to go live north of bum fk Idaho and expect gov support - the fact they are aboriginal or not is irrelevant
I bet if there were Christian councillors in the schools he would fund it like Gina Rinehart on an everlasting cupcake
  • Like 1
is there a steam repository in AU (never used it so no idea)
as if not you would never get close to maxing the connection out anyhow.
Yeah they do. Ive only ever hit a max 1.1mb/s but that was in clayton on ADSL2
thanks man! im going interstate, so anything that looks decent will be great!
shit dude, QLD?
ill check my garage see if i have any spare moving boxes.
A few years back when I had to care about internet quota, I ran a program on my PC which tweaked some firewall rules to block the Non-Bigpond Steam Content Servers... Sometimes it stopped games / updates from loading if the server was too busy (since it couldn't switch to an alternate), but when it would download it'd be Unmetered Data.
Not sure if that's still a thing... but yes, Bigpond, Internode, etc do run some steam content servers to reduce traffic
im with internode and get unmetered steam. its been a god send
pleaseee you know it's bs funding the petrol sniffing outposts that provide zilch to the economy
This
Here are some cliffs so we can just skip it
Hamish quote's Alex's post, reminding him that his beloved Liberals killed the NBN and that he should blow Tony Abbott; Ric comes in with a clever jibe lined with anti ALP sentiment but hardly anyone gets the reference; Hamish pretends to be non-partisan and no one believes him for a second; Al attacks the lazy working class and anyone who doesn't pay a lot of tax including puppies with cancer; Dezz calls Abbott a cocksucker, then somehow gets a payrise for blocking roads in the city
haha so good.
i just pay the $110 and stay at the Benalla caravan park. much better/easier and still get to sleep in own bed saturday night
also, f**k australian games classification. have to pirate Hotline Miami 2 (as per instructions from developer) because the 8-bit looking game didnt pass R18+ classification.
for anyone else keen: https://kickass.to/hotline-miami-2-wrong-number-t10331590.html#main
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
