SIMON intake as well, its sucking in like a thai hooker
Dave's 86 eggd out a sidewall, then completely blew out just past benella
Another FT86 brake caliper blew a seal
32R grenaded a built motor after leaving a BP Level Oil Slick on the track
S15 broke, but then later I saw it driving
Evo blew a turbo
Few commos got booted for noise, warned once for their straight pipes but then didn't do anything about them before going out for the next session :P
Few others with issues on the day
Don't know what car to get next... Probably need to make the ute a daily if I get something newer/better.... Use the ute to tow the bike/trailer etc...
C63 AMG is always on the list, then have to decide 2 or 4 door
35 GTR if I went the jap way... probably has moer wow factor than a c63 these days, and would more than likely rape everyday of the week.
BMW, would have to be a performance model, don't know much about BMW models but I'd have to look into it if the time came..
Audi, like the look but apparently they love to burn oil...
what else?
I remember that with different paint being a hot4s car, seriously though chuck some #Hellaflush #stancemasturbation #lowisalifestyle wheels on it and it'd have all the hipster car scene faggots and mohsen losing their shit all over again.
what else?
C63 is best sounding car hands down. But look so dated now imo and are quite pricey compared to m3s for a decent one with low kms.
M3 coupe is very nice but shape is superseded by the new m4 .. I reckon e92/e93 is better looking myself though
Audi wouldn't touch it after my a5 experience maybe s5s are better but who knows..
35gtrs are still friggin cool but I'd be scared of one without a warranty
Could geta decent porsche for c63 money too..
Car payment money? I paid straight cash for that shit Monica, you know me better than that
Just a bit bored of it Al, that and I drive like 100km a week so all that capital tied up in a car doesn't make much sense
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
