Car payment money? I paid straight cash for that shit Monica, you know me better than that
Just a bit bored of it Al, that and I drive like 100km a week so all that capital tied up in a car doesn't make much sense
Good candidate for a white mid 90s Japanese import
This is making the idea of building a 26 less and less appealing to me
just do a 26/30. those things are unbreakable even though everyone else says they are
IT people, are there any toolboxes or brands that cater for mobile storage of computer leads and the like? i could just get a normal toolbox but thats for tradies.
My car sounds like it now has a dog box. Suspected spigot bearing is on its way out.
Does it make the noise in all except 4th or in all gears?
With the clutch in / clutch out?
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
