Hmmmm maybe I should get something similar for oil cooler setup....
They are ok, if you don't mind waiting 45 minutes for your oil to drain. I removed mine, you can have it if I can find it still.
Sweet! But is there a spool difference between 52 and 56? (Like that's even a legitiment concern on a V8 LOL)
Only 6psi?! I was hoping to run about 15psi on E85 LOL
two TD06 turbo's made 500kw on e85 in Cat's car, at only 6-8 psi I think (gate pressure.) These are larger.
Awwww YEEAAAHHHHH!!! I'm confident now my goal is relaistic, but even more confident my transmission will blow up. Meh
#thuglife
  • Like 1
I'll take it for Leesh's car if it's the same thread
Don't need much boost dat dere v8s
Sif sell the blower! although I do understand that you want that 'lol here comes the power' moment back. instead of having power everywhere which gets 'boring?' sometimes.
Edited by UNR33L
Should've advertised the blower here... I probably would've bought it
I kinda did in my build thread LOL I mentioned it cos I was still thinking about it at that stage and then after thought "f**k it, I'm going turbs now"
but yes... pls run 15psi on e85
PLS
Don't push me, I'll do it!
Yep, that's exactly it! Don't get me wrong, I enjoyed the instant N/A like torque curve of the blower but nowehere near as much as I enjoyed the winding up before the massive spike in torque that a turbo delivers.
And becaue of that, I got bored of the charger and thought it was too slow lol
HG > Garrett
He uses Garrett cores in his BBs anyway, so it's really no contest if he's finding a way to improve on their designs with his own housings
Excellent turbos and I would buy 8 of them if I had 5k to spare
Why don't you supercharger guys just use 1/8th throttle and roll it on progressively faster if you miss the turbocharger feel
Not the same feeling knowing dat power at your feet :(
I used to laugh taking off in first on my GTR without launching you put your foot 100% down, get NOTHING until like 30km/h lol
Cos it would still only feel like a small frame turbo at full boost i.e no kick in the dick we all love from a decent sized snail
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
