how much to spend that was a big call
no way was I spending 3 months salary, not putting a new car on her finger.
but then was not looking to get a brevilles 199 special either.
End of the day I went with approx one engine rebuild as a budget.....
  • Like 1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
