http://www.gumtree.com.au/s-ad/lalor/audio-gps-car-alarms/7-inch-dvd-gps-head-unit-with-iphone-android-bluetooth-usb/1075805006
Was thinking of something like this for myself Martin, think he might stock some single din aswell. Local and better for warranty verse sending back overseas for warranty, but then again you do day trips to China..
Inb4 alex says he can get one in the west
Can only be had in the west. What yall inner suburb hipsters pay for apartments can get 500m2 or more block, 4 bed house few years old with everything!
22kms from cbd
Edited by alr33x
22kms isn't much as the crow flies, but it's my understanding that getting there either with traffic / shitty PT options isn't heaps of fun
Feel free to correct me though, I avoid the west at all costs lol
Edited by HEKT1K
  • Like 2
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
