as Alex will tell you, Newport altona north and your sorted.
I'm at work in south melb in 12 minutes...
This is true but they aren't affordable areas altona north 700k now days :/
Edited by alr33x
700 gets you a hell of a lot there
if you looking to start up and happy to do a little work..sub 400K
http://www.realestate.com.au/property-house-vic-altona+north-119403483
500K will get you a off the plan town house:
http://www.realestate.com.au/property-villa-vic-newport-118286075
That newport off the plan place will be like 7-8 squares at best I bet and the altoba north one is ok value but a unit & needs work & is in a dodgy spot
Wife just sold a knock down job In altona north for $701k!
Edited by alr33x
moved here around 2008...most houses 300-400K
that said find cheaper 12 min from city!
as I mentioned however I'm moving country side, so yeah 5-10 acres would be about right
Altona, Brooklyn etc
Take what you can get at grad level, then work your ass off. Pat and others will tell you the same
Life ain't a drag meet, it's a marathon
I skipped grad position and went straight to engineer position. No time for 3 years of low pay & shit work.
That backfired Monica.
22kms isn't much as the crow flies, but it's my understanding that getting there either with traffic / shitty PT options isn't heaps of fun
Feel free to correct me though, I avoid the west at all costs lol
It's alright depends what time your traveling but it's a trade off your getting double the property for your money but spending more time traveling but have better home quality of life & space etc.
Last time I checked the radio the monash, eastern, ring road etc all sounded pretty shite @ peak hour..
How realistic / repeatable is that Pat? Given the swarms of engineering grads in here who are looking for jobs
I'm gonna stand by my promotion of a good work ethic. Don't see how a pissing contest is going to actually help Jonoe
  • Like 4
Yeah that's fair. I'm neither a family man nor a weekday driver though so I'll stay in my inner east ivory tower haha
I doubt Jonoe is turning down grad jobs cause it doesn't fit/low pay/hard work.
If he is, then harden the f**k up.
If he having trouble securing any grad job, he needs to make himself stand out amongst all the others.
And I stand by my comment of grad jobs. They are hired by HR under their budget & have no clue what makes a good engineer. All they can go off is uni marks which is only one dimension of a productive employee.
Best to go for full time job if you can talk the talk as you are hired by senior engineer & not some HR muppet.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
