Pretty sure Greg and Patrick were
nah man
Ultimately he does make the rules, and if he wanted, he could make wildly unreasonable, unfair rules if he wanted to as well, he could make mandatory blowjobs daily instead of rent.
Of course, if he actually had them sign a lease then uh, there are rules that need to be followed because the law can get involved, too.
Patrick and I were just suggesting a measured, well thought out response is likely better than a knee jerk reaction.
  • Like 1
nah man
Yup both scenarios will lead to a resolution.
Use your power card or struggle through a discussion on an even level.
Both require balls for action so get off sau & do one of them.
waiting to hear from the bank about my first solo property.... i shouldnt be nervious but i am.
lol greenhorn.
a bank will give you an estimate based on a 20% deposit and your income.
Only time you should be nervous is when you push it to 95 LVR & max out your income.
Yeah well I don't even think he has mentioned it to her yet, because when I got home I got an SMS to discuss another day when shes not there, I'm like lets discuss in an open forum around the table with all parties? No reply.
Leaning more towards the Dezz attitude the longer I'm getting f**ked around
Don't forget ya final Inspection
hahaha
Edited by UNR33L
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
