4.28 sounds quite good. Is that variable?
Yeah I think so..
And yeah I was getting those gateway errors too pain in the ass, even with threads ive never been in so not sure how it's a cache issue
What I took from that article is that someone had to do a medical study to tell peole what most intelligent people already knew
That when you take people, pay them large amounts of money that they're not used to making, isolate them in a dessert with nothing to do other than get wasted and high, that they're going to spend that money on alcohol, drugs and hookers.
groundbreaking research
some flog probably got paid a ridiculous amount of money to come to that conclusion to.
Boy did we take the wrong career paths.
What was it about?
I'm assuming it wasn't the union secretary stripping entitlements from workers to bolster his future ALP career prospects...
I don't waste my time reading tabloid horseshit
The ETU is also no longer affiliated with the ALP
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
