Why?
Cold start is a pain; no point having all the power I do when roads are wet half the time; I like to pickle the fuel system in petrol at least a couple times a year to clear any potential build up in fuel rail/injectors/lines; E85 isn't exactly cheap at the moment; will be doing some long distance driving soon and filling up anywhere plus 400km+ to a tank will be handy for that.
Also cold start issues have less to do with the tuner and more to do with when the vehicle was actually tuned - in my case the E85 tune was done in summer where a cold start tune is nowhere near the overnight temperatures of winter. I could get that fixed with a winter tune enrichment if I wasn't lazy, but that still won't resolve the other issues. The fuel on the whole doesn't like a cold engine; it's a good 5 minutes before you see any potential out of it. It's good to do a petrol run for a few tanks now and then.
Yeah mine's not starting at all now... Hasn't run for like 2 months, tried to start it a few weeks ago (N/A with turbo & intercooler bypassed) and it really didn't want to go...
Gotta get Chris to take a look at the coldstart now that it's winter, very not fun when you're cranking for ages and need to let it idle to warm up before you can even blip the throttle, when it's 5:30am and you're trying to leave for a racetrack.
Neighbours hatred is strong.
Get a proper tune/flex if you must.
Or tune it yourself, when my fuel pump actually decides to f**king pump fuel, my car will start in 1-2 cranks in 4C mornings on pure E85. Honestly the difference between starting on 98 and E85 is literally zero.
E85 is quite pricy though, and tbh I considered also just running around on 98 if I literally dailied the car because about 250RWKW of power never actuallyresults in any forward momentum.
But the cold start thing is a pretty huge myth.
I don't think it's a myth given my 98 tune was also done in summer and starts first time everytime all year long - E85 is more sensitive to cold starts, it needs a lot of flow with a cold engine otherwise a summer tune would do you fine through winter.
It can be remedied but ultimately it'll never be as good as 98 or a full flex tune. It's more evident in the more highly strung/tuned vehicles too - I'd hate to do it with a set of lumpy cams and a race car that rarely gets started.
Another consideration is the E content people get tuned on vs a more pure tank down the track. Prolly doesn't hurt to get a touch up tune regardless for fulltime E85 users. Might look into it for this alone.
It could be an ECU thing, but honestly man... starting the car on E75, or E21, or E0, or E84.9 (or whatever maximum ethanol content you ever see is) is... just not a thing.
Starting in summer, winter, I dunno. I read it all the time but it's not like it takes more than 2-3 seconds to have the car started, even with all the numbers wrong.
I have this feeling I just have much more tolerance for the car not starting. If I'm up and going in under 10s I consider that as good as perfect, but in all seriousness I just fired my car up 5 minutes ago and it's coolant temperature is 4C and it was ready to go without stalling or being retarded.
I'd only go back to 98 if I did drive it daily, or had a small turbo where the difference between E85 and 98 was like ~20kw.
E85 is still 20c or something cheaper than 98, say, 1.40 to 1.65, or 117% the cost, for what, 125% of the fuel use? For free powers?
Speaking of farting, did one of this sbd darts where your nostrils just rots...
Did one in my office thinking no other manager would come in yet since it was early in the morning. Nekminut, store manager comes and and yells did you f#ing fart? I smirked and he refused to come in making me come outside for him to talk to me.
Tough times were had keeping a straight face.
If that was the case them why did Caltex run an E70 mixture for their flex fuel during winter for easier starts? Petrol enriches the mix = easier starts. Try starting it on 100% ethanol and see how well you go! Like I said, it matters when your car was tuned. A car tuned on a 30 degree day or a 15 degree cold start is NOT going to bode well come Melbourne winter, not in a concrete underground carpark.
Just filled up with 59 litres of BP. How many litres is the 33 tank? 63? Already enjoying the very low end response (from idle to 2000rpm) of this tune. Lost that epic mid range, though. Should make safer full throttle driving in the wet.
I have a small turbo and in the top end E85 vs 98 is only 25rwkw difference but the midrange is about 40-45. It's no longer the performance bargain it was for the price it is now. Still worth it if you can take the low mileage and limited locations, but it's definitely lost some appeal thanks to United's monopoly tactics.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
