Birds it doesnt look the same though. I have had pumps look much healthier than that one and be completely dead due to far less sediment. Ive also seen my Walbro after some time as it tends to come in and out of my tank a bit..
If you are gonna go 1 pump (which is always better than 2 pumps) then pay the $40 extra and get a pump that will flow 450rwkw on E85.
I'm not following the logic here - are we blaming the fuel pump for how much sediment is at the bottom of a fuel tank? It's what's inside the fuel pump that fails - someone showing an external pic of a fuel pump with sediment covering the mesh shows no failure by cause of the pump...it shows long term use in a dirty tank with the pump mounted too low to the bottom. This will kill any pump eventually, even with a sick filter.
Why? I don't have 450rwkw in the GTS-T and never will...and cbf with wiring and cutting to use a different pump. The 040 is perfectly capable of flowing 600hp+ which is more than I'll need and has been trialed by myself to last 5 years when it's only warrantied for 1. Plenty of people kill walbros and an E85 pump - still don't understand what makes it an E85 pump - is no exception to the same rules that kill non E85 fuel pumps in non E85 tanks.
From the testing I've seen, TWO 255lph pumps running through the factory fuel lines, provides a higher fuel pressure for longer than a single 460lph or similar. 1 pump is not always better than 2.
What I meant was... You don't want 2 pumps and have one die on you.... It's far better to only have 1 pump.. If that pump were to die..
For what birds is doing, the 040 is fine... My point about it dying is my ones died and they looked clean as from the outside. One that looked that clogged but still worked is pretty amazing to me. They didn't need 'much' gunk to die... For me, and I went through 3 of them before I switched to pumps which had external filters (daetschwerks then a 460 when I needed dat flow)
Yeah, I'm gonna go with, stick another 040 in there, or put a 465lph Walbro in there. Either will be fine.
Man, those 040's are crap. Just get the 460L and be done.
http://scottyscustoms.com.au/product/walbro-e85-400lph-intank/
Old mate's shirt in the first pic is fkn fire
You have a store now? Come a long way since the odd job who used to walk into my office/shed to pick up his Sougi!
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
