RACV and lumleys declined due to speeding history and Famous looks to be onto something... so far $200 cheaper than shannons for the gloria. hopefully with CAMS licence and pulsar will bring the quote down a bit.
its important for i also need to squeeze every penny...
gun heaps cheaper tho.
Used to do a heap of shotting.
Won some trophies club champion and represented Uni at Intervasity.
so if I got back into it would be as a club and weekly meets.
I don't go shooting animals.
too much of a pain to lug them home to eat.
How come they give you insurance for 900 yet Pat got quoted 1900 or what ever it was and parked inside a garage?
Actually thinking about going 3rd party on the MV this year.. maybe ride ~2000km a year these days. ~1k is a fair bit for not using it that often.
until you drop it and the repair bill is 5k
Shannon's said cause I fall into inner-city zone & hence the massive price.
Said if I was in Sydney it would have been 2900 lol
Everyone that rides tells me the same thing, who you with? or none cos trackbike?
Don't go 3rd party on bike Leigh
They stolen way too much
Obviously I'd get theft too.. but yea
maintaining a gun / recycling ammo sounds kinda fun.
It's been swabbed.... and wiped.
Everything is clean. Beautiful. So that it slides perfectly. Nice.
Everything cleaned. Oiled. So that your action is beautiful. Smooth.
  • Like 1
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
