You should definitely do DECA Greg. The 2.5 hour drive up there and back combined with a full day of high revving action is sure to end well
believe it or not, I actually made it there and back and did a beginner drift day complete with absolute rev smashing and didn't wreck the car until a week after!
Maybe you need to show your car hard love to get it liking you
I always found Skylines drove much better when you thrashed them rather than babied
They feel smoother and more licence losing
Kind of related
Trying to strike that balance between running down a fuel tank quickly so I can replace fuel pump and babying the car around so it doesn't kill the fuel pump, is a bitch
man forgive me for being so forward or if I've missed something but why is your car such a heap of shit? And surely it's not your everyday car if it's so unreliable?
i dont get some people (not you, well sort of.) who cant be bothered spending money on a licence.
"durhh i wanna do a deca or haunted hills, maybe do a track day sometime. how much of a cams licence?"
"$110"
"aww shit... gets pricey"
you just spent like a few grand on car bits ffs.
Haha yeah 'cbf' probably wasn't the right word it's more the spending money and renewing for one event, $110, $300 tyres, $120 deca etc etc
I'll have a think about it might come up anyway even if just watching / help time
Go at your own pace, don't worry about any other kunt, don't worry about who's behind you (easier said than done when you're one of the slower people in the group) but also don't be the flog who is painfully slow through the corners on his 1000cc then nails it down the straight and doesn't let you pass, only to hold you up with his unpredictable line into the next corner...
When you heading down?
Good tips! yeah I'll scope out the group think i'd do the slow-med to be safe not the med-fast group.
Heading down in September unsure of date yet (getting a voucher thing)
Kind of related
last time mine died was with a completely full tank.
that was a bitch to replace. previous times you knew it was coming, this one just stopped completely.
oh yeah price defs starts to add up. i see the licence as something you pay every year enabling you to attend an event whenever you can. though i understand people who wouldnt get enough use to justify it
I confess not knowing enough about electrical, but can someone explain to me why a submersible pump with a positive and negative lead running to it is never in danger of shorting or sparking and blowing up the whole car?
Obviously disconnect battery before working on it and turn on car / pump brake to discharge circuitry, but I still had a huge fear of something like that happening when I put this pump in first time around and started the car.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
