Don't think there are any rules against it?
But enjoy slipping out on that skidpan and getting destroyed by 4 wheels anyway lol
You'd dominate the longwang / shortwang
those bus stops will be non existing
Don't think the insurance allows motorbikes, just cars.
The front AD08R's still have some meat on them too... they were just thunking a little bit when I was rolling... and you can feel the rough spot... Getting them changed to new ones tomorrow morning.
If anyone wants the old ones (235/40/18's) give me a yell, but I'm not having them clogging up my garage since they won't be going back on the skyline for track use.
watching old DECA vids, 2007 was my last one I think, maybe 2008... Such poor quality footage.
Stopped in the gate on one of the skidpan courses, only to have a spanner fly out of my engine bay
what were you driving?
colour/car?
I have a small archive of old deca vids
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
