"Tourists heading for Greece are urged to take enough cash with them to last their entire stay as Athens announced banks would be closed Monday in a deepening financial crisis."
Maybe I should just paint a big target on my back while I'm at it..
what level of work you getting done? prices reasonable? what about (wait for it)... timeframe?
We are creating in his words a torque monster.
Prices are reasonable by the sounds of it. Timeframe ETA is about a month once they get the car, so using the workshop project multiplier, probably ~3 months. Barry isn't building the engine, just assembling, but there may be other issues I need to address such as clutch, diffs, gearbox etc. which would hold things up.
Excited :)
Lol, never gets old
Simultaneously the strangest and most normal thing I've ever seen in my life. It was a rational and legitimate proposal; why can't they accept 50 x 20 cent pieces as a cover charge, is it not legal tender? But, you just don't do it.
Not legal tender as it turns out lol
http://www.austlii.edu.au/au/legis/cth/consol_act/ca1965120/s16.html
  • Like 2
cool. low-down torque or never-ending-spool torque? im sensing stroker kit and mild cams (but strokers so pricey).
whos building engine then? or is that trade secret?
Is it the 750 that is the original or was that a special edition size?
750 = not AU market
Am I the only one around here happy with beers?
no, I LOOOOOVE beer. it's just that it's not worth talking about like scotch
  • Like 1
Torque everywhere torque
Real McCoy "Another Night" torque (I torque torque, I torque to you)
Engine already built; under wraps til it's done!
I got torque and my turbo is literally too small, so go get some 500KW low mounts
Also expect 1 year until its working
Unless you are just flat out buying an engine which is in stock which c'mon man does not ever seem to exist
We'll see - full story when it's put together :)
But yeah I may not be keeping my HKS GT-SS
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
