I'm confused, you entering with the BRZ?
or is your mum actually driving too?
Mum driving 86
I in Skyline
If you DECA lads can put us in the same group with my number about 10 cars apart that would be awesome kthx; would not mind passengering for her skidpan runs
I wouldn't mind passengering her skidpan runs too
Fondest memory of skidpan is passengering Hamish's car watching him rage that he couldn't get any power down, shouldn't of sold it brah.
Surprising - they were hub kw
  • Like 1
lel
maybe I should just enter the falcon, not go for times but entertainment / smoke value - still trying to convince chris to come up and let me be second driver :P
Edited by UNR33L
lol... tell me about it!
