Tomic may be a flog but Tennis Australia are the ones acting like Goodes - harden up princesses, you cop some criticism and think you're untouchable.
We can go through point by point on all the accusations that were made and have a response to it. Many of them were very inaccurate and the rest of them were just untrue."
= equivalent of "We have a response to the criticism, we just don't want to tell anyone because we decide the rules and you respect our authoritaaaah"
It's like any job in a corporation. Princess Tomic needs to harden the f**k up
They're the ones who started with petty shit like making him pay for court time and tennis balls :/
That's like you criticising your boss for something you feel strongly about and instead of him responding to it or taking a more nature approach to dealing with said criticism (some of Pat's change management due here), he says well you can pay for your own coffee at lunch breaks and use your own internet access now - fkin playground mentality.
Obviously there's been shit going on, hence their unwillingness to respond or it would be as simple as shutting him down with the cold hard facts - guessing these probably don't work in TAs favour though. Glad he had a go at them, need more sports stars who tell it like it is (Mick Malthouse etc.) instead of letting corruption and bullshit go on in sport because people are worried about losing their overpaid salaries.
  • Like 2
Perhaps he should be grateful for all the help & most likely free training he received through TA / AIS and actually repay the faith shown in him instead of telling us all how too he is actually go out and win some worthwhile matches
Respect is always earned
And that's life. You have bosses that you don't like, and you suck it up like a f**king man.
If I was on TV i certainly wouldn't be slagging off NAB and crying aboit being victimised by the police "because they are racist"
Lets set the record straight. TOMICH started this all by being a gigantic flog.
  • Like 1
Feels strange agreeing with you on something
It's also a two way street...you can't expect people to respect you regardless of your position of power if you act like a jack ass. People who say "my game my rules" end up playing alone.
Which is why bosses who don't respect their employees end up with poor employee satisfaction and a high staff turn over. Do it enough and their bosses start asking questions too.
Lot of this Tomic hate stems from jealousy cause young kid with lots of money having a bitch about something...meh...I say good on him, at least he's standing up for himself instead of just prostituting his dignity away for the sake of earning $$$.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
