Australia is notoriously tight assed when it comes to taking in refugees and ahem, boat people.
Like wildly so. We're really Xenophobic by comparison. It's one of the biggest beat-ups in Politics, it's right up there with running two intake mods murdering small children according to ACA
How is it xenophobic...I look at it from an economical standpoint; could give a stuff where the people are from.
That's similar logic to "does not agree with gay marriage" = homophobic
"dislike of or prejudice against people from other countries"
Our staunch resistance to immigration makes other people view us as Xenophobic, when nearly every other country in the world takes widly more refugees/immigrants/boat people and it's not an issue (or not nearly as big an issue) for those respective governments.
We kick up a huge stink over what most would consider an absolute non-issue.
http://www.factsfightback.org.au/does-australia-take-the-most-refugees-check-the-facts/
The numbers are out there. We're not the worst, but we aren't exactly a humanitarian open the floodgates, bring in your sick, poor and frightened beacon of welcoming respite for those in need.
what about the number of asylum seekers vs. visas granted/immigration numbers? most of the countries in the top 10 probably wouldnt have too many people applying to move there... and rather look at where the people are going, maybe its more important to look at where theyve come from.
Australia is a long way for asylum seekers to travel. its dangerous, probably expensive and very risky. If you were trying to get out of Egypt or Israel or palestine, getting to Jordan is probably a lot easier. like walking from Fitzroy to Frankston. its not going to be fun, but its doable.
in summary: charting of countries against each other is pointless.
What resistance to immigration? We take in plenty of immigrants, through our legal channels. Australia is hardly an all white population; probably the most multiculturally diverse country in the world. We even have investment schemes and working visas set up for immigrants. If other countries view is as xenophobic...and I don't know who these are...perhaps countries who wouldn't be willing to take the boat people either...that's their problem and I could give a fk less.
But...I'm pretty sure most countries consider illegal immigrants an issue. Look at America with its border protection policies against Mexico and the south, and almost every sane developed nation against their neighbours.
Putting boat people who are trying to queue jump those taking the legal avenues to seek refuge, into the same category as the latter, is dumb. They are a different kettle of fish, even if their goals are the same.
I'm not interested into turning Australia into the sort of places a lot of the boat people come from, which is what happens when you hve unregulated immigration and burden your economy with thousands of other countries' problems before you fix the many in your own backyard.
FKN lol they haven't stopped any boats and it's still a farce costing bililons.
The boats still come, and people's lives are still at risk, the only difference is they intercept them in international waters now & try not to report the details.
I vote Hamish for PM
Prevention is better than cure
There are much less boats coming under Abbott's regime and incidentally less deaths too
It's about sending a message that they will get nowhere here so try somewhere else - that message is being sent now
Labor's version made every boat person:
54276-So-youre-saying-theres-a-chanc-a7G
Turning a boat around and having people die somewhere else then not letting the press know =/= less death.
hamish you cant be serious? its not Australia problem these people get in shitty little boats and try to illegally enter another country, do you think if you hopped in a little rusty dingy heading to China they would give two shits about you? no it would be your stupidity. Same applies for these economic refugees. (possible terrorists)
Its factually correct that Liberal has reduced the amount of boat people and the policies have deterred people from trying as opposed to the record number of arrivals under Krudd, Gillard & co.
  • Like 1
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
