napster? limewire? or better yet was this being shared around on IRC......
just give him the link to the MP3 you have secreted around somewhere.
send me the link as well.
kazaa? imesh?
IRC downloads through bots, downloading 100x 5mb zip files.
Heart goes out to iMesh
Fantastic porn service with preview option
Ahhh the days of having to trust file names for their content and judging a file mostly by its file size
just so long as it was not the jamster frog..
that was both the worst and best thing we ever did.
I can tell you right now that when it came out Scott Alert (Ric will know) had that ringtone
  • Like 1
that that helped our CEO's christmas bonus.
and what large bonus' they got from it as well
from https://en.wikipedia.org/wiki/Jamba!
In late 2004 under Irvin's direction, VeriSign bought Jamba for $270 million.
Jamba/Jamster boomed—when VeriSign bought the business it had a turnover of $15 million per quarter and 3 quarters later this increased to $150 million a quarter—in 2005 the company made close to $600 million
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
