He kind of gave you that warm fuzzy feeling of everything being okay in Victoria
Jeff had his shit together
I couldn't even tell you who the premier of Victoria was past Steve Bracks - they haven't stood out to me as important since.
He's a sexy guy
He used to make numerous visits to my highschool for award presentations when he was just a member for mulgrave.
No one listened to him & everyone talked over his speeches & now he running the joint.
Quite ironic seeing as those students probably voted him in...
lol @ basing their decisions on preventable accidents that happen as a result of hospital negligence.
I know I'm preaching to the choir here, but since when was private health insurance there to influence or protect the actions of the hospital? Last I checked it was there to cover patient expenses in hospital. They are the client, not the hospital.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
