Vic Wasteland Thread
R31Nismoid
new kid: lets see how professional you are, show me with your hands how big 600mm is.
me: shut the f**k up, grab a tape and measure it you lazy flamin mongrel.
will this flamin mongrel be number 2 this month? maybe
must be awesome working for you.
Dezz turning up the fashion volume
Nek minut pink dinner jacket
They'd have to put it on my dead body in the casket
Dezzmang with the lingo
#windsorknot #mensfashion #dapper
#ganghnamstyle
The head of contracting was miring my outfit last night
Could barely walk by the end of the night... Give me air max any day
I ended up going with a size 43, she talked me into that after I tried on the 44 saying they'd give a lot with some wear... They started off fine, so I'm guessing the size isn't too small but they are pretty tight, and I won't wear them enough to break them in anytime soon...
Anyone else wear a 43 dress shoe and wanna break in some pimp italian leather shoes? Shits are Ric 'sharp as shit' certified
it is, but when theres heaps of shit to do and youre slacking off trying to start conversations about irrelevant shit, just like when youre in school. im going to be a flamin mongrel.
when you dont take the time and money i invest in you, with training etc, or when you cant answer a simply question, or know what a coolzone is in a fryer and then laugh it off when i hammer you about getting to know the product. i will defineately be a flamin mongrel.
come work for me Alex, if you can sell a house, you can sell a fridge.
Do your fridges run well?
Where em around the house a bit to break em in cos it'll be a pita first outing otherwise
#ganghnamstyle
Toe not pointy enough, would not bang
Just when I thought you were at maximum Monica status...
  • Like 1
Last night was the first outing, was not fun.
That's a shame cause you could just about play a game of basketball in these
You think Ric doesn't make sacrifices every god damn day to look as fly as he does?
My comfort is my look
Guest
    • Vanos solenoid problems and basically all sensors die an early death
    • Yep, back in the day when you could pick up a Stagea RB25 NEO for $1,500 it was worth it. These days... just chuck your V8 or B58 in.
    • from my limited BMW experience: - they burn oil WTF (B48 FTW 170kW engine) - dump oil every 5,000km and you'll be ok.. until it drops a bearing and rebuild time. replace engine with B58
    • I would avoid the AWD motor in a RWD using a modified RWD sump and pickup. The way the pick up is positioned, you'll have oil pick up issues on hard acceleration on a track around bends. Even with a baffled, gated sump. I suppose if you don't race on a track and it's used for straight line activities or street use you might be ok.
    • They absolutely are, but the thing is, if you're only exposed to these circuits for a while, what I normally think is good driving suddenly isn't so much. I was a pussy at the Nurburgring (GP) entering corners at 180kph - the difference in the balance of the car suddenly becomes so much more pronounced and I'm still a bit regarded at left-foot braking - something I now practice on my commute. So the (dream) plan with the E90 is to make it a 325i Cup car. Whether I get there or not is another matter. In my mind the simplicity of having the NA variant and cost made it a bit more appealing. Plus, like mentioned above, I'm actually too much of a pussy for big power. Of course I f**ked up by not researching enough on the N53 vs N52, the latter being more robust without the DI system.  Suspension-wise on the BMW, and I've been reading the technical requirements for the 325i cup, basically everything except struts has to be standard - bushes are free. I figure you get about 5-10mm adjustment with the rear camber bolts which should translate to 0.5- 1.5 degrees of adjustment. So with coilovers, lowered at 30/40mm I expect I can dial out some of the camber from a drop and attain -1.5 to -2. If necessary, I could get the same effect as the M3 arms with some offset bushes. There is a limitation on ARB width to qualify, although I absolutely want to get either M3 ARBs (can't say sway incase I upset GTSBoy) or the H&R ones - both of these are the cheapest options. Like mentioned, M3 arms are on the way and I should have them fitted within the next week. How are the BC Racing coilovers btw? Reviews are mixed but I think for me they would be fine; a friend of mine uses them on his R34 for track driving and has nothing bad to say. I'm looking at these or the ST coilovers (German brand, new to me) as prescriped the in Cup spec sheet. They're both similarly priced and offer camber adjustment. It's fine but it really upsets my OCD. I've got a couple of options for dialing out the rear camber and keeping my ill-fitting wheels: raise the rear a little bit, say 5mm, that should permit -2.5 camber or drop the front to restore that slight bias of more negative camber up front (not optimal with the roads here). The next alignment won't be until at least next year and I really need to rebuild the rear subframe. For now, I'm not using it at all on the streets except occasional blasts through the German countryside. I was covering about 10k kms p/year in Japan, I expect this to now be about 3-4k. You could say buy better sized wheels, and yes, I should have. But the wheels came from the Z and price of good wheels is just insane now. Again, a couple of options: get a new set (I want 17" RPF1s) or buy two used 9.5J TEs, both are about the same price excluding shipping.
