prob is a legit one,
there diffrent plates for diffrent areas
so M means melbourne
ST would be a diffrent area and might have used to get into melb
edit:
Substitute Taxi Plates
These plates are issued to "spare" vehicles which replace licensed taxis when they are off the road for repairs. Substitute taxi plates are issued in the series ST 0000 to ST 9999.
[No image avaliable]
http://www.vicroads.vic.gov.au/Home/Registration/NumberPlates/StandardNumberPlates/TaxiNumberPlates.htm
So is there like a min or max amount of litres required for each donation?
I'm sure even the smallest amount is workable. Its more important that all the sperm are alive :)
I'll find out some more info and keep everyone posted :P
spermlinesaustralia
If ANYONE is thinking of donating sperm, you are fkn stupid unless you are genuinely doing it to help out families that cant have children....
I'm not even gonna go down the hormone charged, loved up, holier than thou, new dad line....
we all know it's selfish etc etc
BUT THINK ABOUT THIS...
This is Australia... and laws WILL change...
God knows you will probably end up having to pay child support for 10 kids you never wanted or face a bunch of fines etc.
100% BAD IDEA
Guest
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
