When exactly are you eligible to get your new car kaitoukid? Or are you already off your P's?
Nope, still on the final stretch of them ! To be honest if I got them on time I'd be free in 2 months :'(
Sadly as it stands, early '14.
However I'd say I'd be looking at the end of this year to actually get one, if all goes to plan. It'd be summer, so I think I'd be right with daily-ing the bike for the overlap :P
/currentplans
no idea... most peeps run around 23-24psi for that I think
Hmm I see.
see it's just not worth the hastle...
e85 will get me to what, 250awkw vs 230?
and for that I need to do injectors and make huge efforts for fuel
that's a lot of effort for less than 15kw/tonne
We aren't talking about the evo oz mail order tune here... :P
So extend the tank with a 20L fuel cell/surge tank like I am doing in the Stagea... I doubt you would notice an extra 20kg in the boot.
You have a spot for it, and your spare wouldn't fit over your brakes lol. You can swap the e7 tank with the e9 and get another 20l I think.
Supposedly a straight swap
whats peoples opinions on under/overdrive pulleys? and also lightened crank pulleys? 4 cyl's dont have the same level of harmonic balance issues that 6 cyl's do.
Some talk of 350Z lightened pulleys giving way, but the ones im looking at are billet aluminium alloys
He died with the rave scene.....
"DJ's" use CD's now and I AINT GONNA BE A PART OF THAT SHIT!
lol CDs, I wish. Today's DJ uses a USB stick or an iPod with a preset playlist he made 6 months ago. You make a request and you get told sorry it's not on my playlist, instead of sorry I don't have the 45...
I much preferred the latter as a form of rejection.
majesta
Nice!
Year / model / mods?
+1
And please welcome, "DJ Press Play" to the stage!
Guest
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
