with 90's nissans, do you think the airbag light only covers the airbag deploy equipment (gas, charge etc) or do you think it covers the actual sensor(s) as well?
I think sensors are part of the light, could be wrong.
thanks Grant,
Just found the Series2 N15s is Aus (which didnt offer passenger airbags, cheap bastards) had an accelerometer in the steering wheel/driving column. not a sensor. hmmm answers my question.
apparently JDM or Euro N15s with passenger airbags had an accelerometer behind the handbrake lever
i have meatier tyres, but you gotta pull them off those v35 sedan wheels, because those wheels dont fit the gtt.
Hmm... that means I have to get another set of wheels or ask Tony if it's ok with him for me to do that to his wheels. I'll see how I go with finding another set of wheels.
I swear RWC places/Vicroads are there to troll car owners.
forum broken?
Works ok for me.
if you want, i have a set of gtt wheels you can take along with the v35 wheels lol.
Now, that isn't a bad idea... Need to borrow dads Corolla to fill the wheels up.
Would my AVS Model 6's fit Grant, they've got a heap of meat on them... like 80%?
And about IE... IE rocks nowdays... We're not still using IE6 anymore... there's a reason that it's used a lot in the business world still, its actually pretty easy to manage and lock down in a large environment, unlike other browsers out there... and it integrates with other MS products very nicely.
Guest
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
