I finished story mode tonight, and sitting on 86% completion... will work my way towards 100% slowly :)
fair effort.
what properties do you own/recommend?
what a beast. so much toob.
http://www.speedhunters.com/2013/10/have-wings-will-fly-inside-the-peugeot-208-t16-pikes-peak/#chapter-making-history
fair effort.
Well you can buy a whole lot of properties with the money that you get from The Big Score near the end, the final heist... and you only need to buy 5 properties for a 100% hurdle... Honestly you're never going to get a lot of income from properties compared to income from heists... But I recommend getting the property with the wooden staircase down to jetty near the top left of the map, this lets you go track down nuclear waste in the ocean at $23,000 / barrel... But as I said, you don't need money in the end...
5 properties eh?
I have 2 bars, los santos customs, smoke on the water and the sonar property. Sonar was a good buy, others arent all that special. Thought maybe some might have had their own mission set or something. All my characters are rerally poor except for trevor who did well on the stock market lol
Note: Los Santos Customs is so annoying being out of the way. feel a bit jibbed only accessible to one shop and one character. oh well, no such thing as a free lunch
Yeah I meant story mode...I'll keep playing and go for 100%, but I get bored easily so we'll see.
Does BAWSAQ or whatever it's called work for anyone else here? Mine always says down for maintenance, wondering if it needs an internet connection to work coz mine hasn't been connected lately..
My mate got to 100% the other day, a lot of time spent finding shit etc
BAWSAQ is linked to the global usage of items in the gta universe, people (players of the game) buy a lot from Ammunation, stock goes up. People blow up a lot of FlyUS planes, stock goes down.
I've been doing stunt jumps and stuff... but something went wrong and now its bugged a bit... Says "undefined" instead of the completion count... so I'm missing 1 of the 50, but don't know which :'(
Guest
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
