Why?
Cold start is a pain; no point having all the power I do when roads are wet half the time; I like to pickle the fuel system in petrol at least a couple times a year to clear any potential build up in fuel rail/injectors/lines; E85 isn't exactly cheap at the moment; will be doing some long distance driving soon and filling up anywhere plus 400km+ to a tank will be handy for that.
Also cold start issues have less to do with the tuner and more to do with when the vehicle was actually tuned - in my case the E85 tune was done in summer where a cold start tune is nowhere near the overnight temperatures of winter. I could get that fixed with a winter tune enrichment if I wasn't lazy, but that still won't resolve the other issues. The fuel on the whole doesn't like a cold engine; it's a good 5 minutes before you see any potential out of it. It's good to do a petrol run for a few tanks now and then.
Yeah mine's not starting at all now... Hasn't run for like 2 months, tried to start it a few weeks ago (N/A with turbo & intercooler bypassed) and it really didn't want to go...
Gotta get Chris to take a look at the coldstart now that it's winter, very not fun when you're cranking for ages and need to let it idle to warm up before you can even blip the throttle, when it's 5:30am and you're trying to leave for a racetrack.
Neighbours hatred is strong.
Get a proper tune/flex if you must.
Or tune it yourself, when my fuel pump actually decides to f**king pump fuel, my car will start in 1-2 cranks in 4C mornings on pure E85. Honestly the difference between starting on 98 and E85 is literally zero.
E85 is quite pricy though, and tbh I considered also just running around on 98 if I literally dailied the car because about 250RWKW of power never actuallyresults in any forward momentum.
But the cold start thing is a pretty huge myth.
I don't think it's a myth given my 98 tune was also done in summer and starts first time everytime all year long - E85 is more sensitive to cold starts, it needs a lot of flow with a cold engine otherwise a summer tune would do you fine through winter.
It can be remedied but ultimately it'll never be as good as 98 or a full flex tune. It's more evident in the more highly strung/tuned vehicles too - I'd hate to do it with a set of lumpy cams and a race car that rarely gets started.
Another consideration is the E content people get tuned on vs a more pure tank down the track. Prolly doesn't hurt to get a touch up tune regardless for fulltime E85 users. Might look into it for this alone.
It could be an ECU thing, but honestly man... starting the car on E75, or E21, or E0, or E84.9 (or whatever maximum ethanol content you ever see is) is... just not a thing.
Starting in summer, winter, I dunno. I read it all the time but it's not like it takes more than 2-3 seconds to have the car started, even with all the numbers wrong.
I have this feeling I just have much more tolerance for the car not starting. If I'm up and going in under 10s I consider that as good as perfect, but in all seriousness I just fired my car up 5 minutes ago and it's coolant temperature is 4C and it was ready to go without stalling or being retarded.
I'd only go back to 98 if I did drive it daily, or had a small turbo where the difference between E85 and 98 was like ~20kw.
E85 is still 20c or something cheaper than 98, say, 1.40 to 1.65, or 117% the cost, for what, 125% of the fuel use? For free powers?
Speaking of farting, did one of this sbd darts where your nostrils just rots...
Did one in my office thinking no other manager would come in yet since it was early in the morning. Nekminut, store manager comes and and yells did you f#ing fart? I smirked and he refused to come in making me come outside for him to talk to me.
Tough times were had keeping a straight face.
If that was the case them why did Caltex run an E70 mixture for their flex fuel during winter for easier starts? Petrol enriches the mix = easier starts. Try starting it on 100% ethanol and see how well you go! Like I said, it matters when your car was tuned. A car tuned on a 30 degree day or a 15 degree cold start is NOT going to bode well come Melbourne winter, not in a concrete underground carpark.
Just filled up with 59 litres of BP. How many litres is the 33 tank? 63? Already enjoying the very low end response (from idle to 2000rpm) of this tune. Lost that epic mid range, though. Should make safer full throttle driving in the wet.
I have a small turbo and in the top end E85 vs 98 is only 25rwkw difference but the midrange is about 40-45. It's no longer the performance bargain it was for the price it is now. Still worth it if you can take the low mileage and limited locations, but it's definitely lost some appeal thanks to United's monopoly tactics.
Guest
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
