Sounds like coilpacks or spark plug - a cylinder or two isn't firing. Unburnt fuel going through the hot headers or turbo(?) is what's making the cat glow.
If it does it at idle, you can diagnose by running engine with bonnet open and pulling/replacing each coilpack individually until you find the one that makes no difference to the engine sound. Then when you find the faulty cylinder, swap it's coil pack to another cylinder and see if the problem moves to the new cylinder. If it does, then coilpack. If it doesn't, then loom or spark plug in the original cylinder will most likely be it.
twas indeed a broken coilpack :)
funny, i had just finished making up the carsales ad for it when i went out and noticed it.
could be a sign? :closedeyes:
Good stuff^ could have been much worse. Could have been a sign that you're meant to keep it but most people take a car falling apart as a sign not to lol.
Have you decided who will do mechanical and tune brah?
I'll do the mechanical, not sure where to get it tuned yet. Recommendations?
Car will be driveable off boost with the high flow fitted...might leave standard injectors / ECU in there and baby it to the tuner. Tao did recommend Trent cause of his familiarity to the turbos, said it would be easy to tune off previous maps rather than start from scratch.
Power fc Birds? If so you can change settings to suit bigger injectors/afm quite easily. Then just stay off boost on your way to the tuner
Forgot about this, never used a PFC before but if it's that easy I'll look it up / get you to show me. I know there's a reset which defaults it to a really conservative "limp mode" allowing you to baby it to a tune.
Guest
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
