+ the turbine housing so easy another 500+
"most" of the guys that would use them would have the rears off a -5, 2530, RS or -10.
The big cost is the intake piping.
The guy I was spekaing to wanted to come and have a look at my engine bay when the engine and turbo's are in. He may have an idea.
Does this mean you are making the switch to these turbos now piggaz ?
Nah. I'm keeping the little 5's. It made 426 at 22 psi top end. 450 was only a intake cam twist away. That will do. I'm not too keen on the whole custom piping. OEM airbox FTW!
  • 3 weeks later...
i was interested in the GTX2860 on my car too. What are your specs you got the 2863 right? i have a stock engine, but i will be putting tomei 260 cams in. I am not looking at making more than 550whp as i have my RB26 in a old Datsun 240z, I think anymore than 550whp would be a death wish for sure. Do you think it would be worth it vs the GT2860-5? I would think i would use the smallest ones i could, i wish they had a compressor map but i dont know how to use them anyway. I am also considering the borg warner efr with internal gate for a small or midside single turbo, but i do like the curve of the twins. What do you think?
On a WELL setup car you will get close your 550 rwhp with the normal 5's. If you go that way you won't have the added complexity and expense of the custom intake piping. Will it be on e85?
Pump gas. I do all my own fab work so it might cost me 100 bux for the argon and the piping. Although i do value my time these days... I was curious abou the -5 and the surge. i dunno what i'm gonna do. I was trying to hold of for the EFR borg warner turbo but its always 3 months out and i kind of light the curve of twins. Traction is an issue, but i can control traction and boost via aem ems V2 so not too concerned.
Edited by ZT-R
What do you mean by setup correctly? I'm in the States so we have 93 as pump. My current setup is
1972 240z with RB26 engine.
Engine and Drivetrain:
97 RB26DETT
99 R34 GTST RWD Transmission
Carbonetic Twin Disk Clutch and Flywheel
AEM Series 2 EMS
AEM XWIFI
AEM Boost Solenoid
AEM 3.5 Bar Map Sensor
Tomei Oil Pump Modified for External Pickup
Tomei Cam gears
ATI Crank Pulley
Greddy Timing Belt
Nismo Low Temp Theromostat
McKinney Motorsports Oil Pan Modified for External Pickup
Greddy Underdrive Pulleys
Huge 4" Bar and Plate Intercooler
HKS SSBOV
Jun Style Intake Manifold Modified for S30 Chassis
Wilson 80mm Throttle Body
Jacking Racing Throttle Body Rotor
Lokhar Throttle Cable
Godspeed Fuel rail (I know)
Infiniti J30 Ignitor
(3) Walburo 255HP Fuel Pumps
Aeromotive Fuel Pressure Regulator
Custom Surge Tank Housing Twin Walburo 255HP Fuel Pumps
Modified Fuel Tank with Sump and Internal Baffles
8AN Fuel Lines
Aeromotive Fuel Filter (Secondary)
Earls Fuel Filters (Primary)
Gizzmo Thermal Intake Gasket
R230 VLSD Differential
Custom Mozer Axles
Greddy Oil Cooler Sandwich
GT Cooling Mod
PRC Radiator with Built-In Oil Cooler
Spal 16" HD Fan
Custom Intake with K&N Filter
Custom Oil Catch Can
Custom Overflow Can
Optima Red Battery
Dual 2.5" to Single 3" Dowpipe
Custom 3" 304 Stainless Exhaust
Vibrant Ultra Quiet 3" Resonator
Megan 3" Turbo Muffler (I know)
Countless Earls Fittings and Hoses
Hmmm. What I think the Zeeeb is saying is that your air intake is drawing air from behind the hottest part of your radiator...
You could go a long way to improve your setup by just moving the air intake. Perhaps to behind the left headlight. Or even box the filter in close to the left guard and duct air from behind the headlight to the filter. You might have to move the radiator overflow to where the filter is, but there will be room.
You can only "get away' with that kind of intake setup if you happen to live in an area that has typically <10 degree C ambient temps, because your thermostat will barely be opening and as a result your radiator core temps (and exhaust air) will be much lower.
Designing an optimal setup in conversions is always a challange because the cars were never designed for that kind of setup.
Belive me I tried. There is no room for anything in this bay. If I stay with the twins i am going to make a duct for the filter. I kinda planned on going small to midsized single turbo from the start. This setup is just to get the bugs worked out before I make the horsepower jump. After seeing a lot of dyno graphs on singles I'm not so sure i want that kind of power curve. Most seem like they are off and on. Granted with the EMS i can do all kinda of traction and boost control so I just just say screw it and do it anyway.
Edited by ZT-R
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
