Are the tomei REAL 3 inch dumps? That´s the only one I could find where you can see the custom dump pipes...but it was before the GTX came in.
Series 1 are 72 mm internally.
Series 2 are 68 mm internally.
I have to measure again, I think I used 80mm pipes and bends, so 76mm inside diameter for each turbo until the cat converter, then 88.9x2mm to the back...as the cat is the biggest restriction anyways.
That´s why I used two catalic converters on the GTR, and after the middle box there´s a 114.3x2mm pipe towards backbox + end, as this was the biggest possible diameter between rear axle and LSD :D
Edited by AndyStuttgart
I can prove otherwise on my own car. do a bit of clearancing with a die grinder, wrap the dump pipe, done.
Give it 18months and then see.
I killed 2 silicone joiners on a low mount setup /w heat shielding over the course of 2 years simply due to radiant heat.
Sean has certainly done it right the first time. I'd never silicone in that area again.
  • 3 months later...
Spat a bolt out of the turbine housing on the rear turbo, so exhaust leak...
My fault as I only used bolts and washers to attatch the rear housings, as they don't come with attachment hardware.
Permanent fix this time with the correct half retainers from some other turbo's in the shed.
Next time I go on a dyno, I'll put up a sheet.
Yeah do everything myself at home including engine builds lol....
Yep twins are fun, 6th time ever on GTR's now....probably 4-5 times with engine in the car, stubby ratchet ringies are your friend :D
here are some pics of a local newcastle engine builder & his latest project.
gtx snails with a few other goodies...take note of the intake plenum & flux capacitor. absolutely awesome fabrication work!
I can see one of the goodies from here... that sneaky Newcastle fella!
Had a play with a nice GTR with a set of the GTX's (modified -5 front covers) last week we ran out of spark (see dip) @ 460rwkw on E85 @ around 23psi definitely good turbo s even with the hybrid front cover..
Had a play with a nice GTR with a set of the GTX's (modified -5 front covers) last week we ran out of spark @ 460rwkw on E85 @ around 24psi definitely good turbo s even with the hybrid front cover..
What size wheels? 60, 63 or 67's?
Yeah what size? And what sort of response?
Edit: see the graph now
Edited by jangles
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
