I planned to put a 3076 on my rb25 with a high mount setup on my car, however it all started to add up price super quick. Have realised i dont want to spend to much more on my car :P if possible.....
Now i am thinking of going one of hypergears turbos, either the ATR43G3 or ATR43ss
I would like 300rwkw on the stock manifolds, and would like to use a dual stage for street use of around a bar, or whatever gets 250rwkw.
My question is what turbo? the more power (around 300) on lower boost would be more reliable?
if so i would be better off to go a ATR43G3? has anyone had any actual experience with these?
Would be nice to just be able to bolt it on, same water lines, comes with oil feed and spacer plate. also exhaust bolts straight up to standard for $1480 shipped
My supporting mods include Haltech e11v2, bosch 044 and surge tank, full 3" decent clutch etc.
Also what injectors?
i know 550cc will get you 300rwkw but as it is my daily i want the best fuel economy i can get,
my tuner said he tuned an rb25 with simmens 600cc injectors (i think ) and it was getting crap fuel econ. He put in ID 1000ccs and got 2km per litre better economy? 60 litre tank = 120km each tank more!
For you guys with around 550s and a 3076 size turbo what economy do you get?
or would i be better off spending 1k for ID 725cc injectors and a rail to suit for good fuel economy.
Any help much appreciated :)
Cheers, Chris.
  • Replies 158
Posted Images
I think the SS series of Hypgergear turbos are the best, their response is significantly better imo. For that power level I would choose the SS2. People have made 300rwkw using the SS2 on 98 fuel on around 20psi. I personally wouldnt choose the ATR43G3 on a standard rb25 as it doesnt have the best response.
Its not the injector size that gets you better fuel consumption but the spray pattern I believe. If its not a neo then you can use nismo 740cc injectors which are very popular.
First of all , make your mind up whether you want 300rwk or 250rwk , don't waste your time with changing boost pressure , you can do that with your foot (if the haltech can , drop your rev limiter down if you don't trust yourself) , second , the way my tuner explained injectors to me is vaguely : for fuel economy and better tune spend the $$ on decent proven injectors with a good spray pattern , they will pay for themselves in the amount of fuel they save compared to buying bad quality ones :)
I have a Garrett GTX3071 on my standard manifold and have 850cc Power enterprise injectors making 288rwkw on bout 21psi and i get bout 450km out of a tank of juice but my car isnt a daily drive so when i get in it i generally head for the hills for some spirited driving :nyaanyaa:
My last tune when my nistune was installed with the standard turbo made 203kw on 12psi and my fuel economy was almost 100km worse on a tank of juice than it is now with 85kw less!:blink: So i guess the tune has alot to do with fuel economy also mate :thumbsup:
Cheers, Chris.
So what sort of spray pattern should an injector have to return good fuel economy??? Can someone explain? I was thinking of getting siemens deka 60lb top feed high impedence (EV1)injectors for my R34 NEO from ebay $279 for the lot which is darn cheap! What sort of spray pattern do these have and are they 'inefficient (fuel economy wise) injectors' seeing as they are cheap??pinch.gif
Thanks heaps for the replies :)
Well i may as well go for 300rwkw, he has just dynod a turbo that made 325rwkw on 20psi I think, and 200rpm response better than the g3 I'll look into it a bit more...
Mick_o, that's good! That's more than my car gets now standard haha, what kind of response do you get with the gtx3071? standard motor? What about inlet manifold?
What would be the most pressure you can run with the standard motor/inlet manifold? Think my tuner said he has had to put a fair bit more fuel in certain cylinders with the standard inlet manifold above 19psi.
The guy from hypertech dosent use an adj. Exhaust cam gear either so maybe I cam get a little better spool rate there :)
May as well get the id725 cc injectors, more room to grow anyways and apparently really good on fuel.
Thanks heaps for the great replies, keep em coming :P
Also Harey, the ss2 does look good :)
If you have a look at the rb25 dyno threads he put the new turbos dyno sheet up there, it looks like a good compromise between the two.
What kind of response have you seen between the two?
And yeah the Id injectors are supposed to have a very good spray pattern,
+1 for the 2835 pro s, mine is running 280kw @18psi and very responsive (with other supporting mods such as cam gears etc)
With nismo 555 injectors and a tune ever so slightly on the rich side I'm still getting around 430-450 k's out of a tank.
FWIW ~280kw makes for a dam fast street car especially a well setup gtst
I was surprised by my fuel economy but my car was tuned by yavus at unigroup and hes the go to man! Lol my motor is completly stock other than the go fast bits i see full boost in 2nd gear bout 3800-4000 3rd gear is prob 3500ish ive had near 27psi into my car few times briefly with no probs! Im thinking bout scrapping the nistune for a link G4 ecu and an E85 tune and 25psi + boost real soon :-)
................r it all started to add up price super quick. Have realised i dont want to spend to much more on my car :P if possible.....
While the HKS 2835 is a GREAT turbo it's not exactly cheap. If it was even remotely cheap I'd have one myself.
I woulda been waving that flag too but it didnt exist when i was in the market for a turbo :-( still happy with the garrett response probably isnt as good but when its on it still kicks ya up the ass! Haha
This is very true, one big bonus is you get everything needed to make it a true bolt on.
But I do agree you are paying extra for the hks tag, but you forget about it when you push down the right foot :)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
