I planned to put a 3076 on my rb25 with a high mount setup on my car, however it all started to add up price super quick. Have realised i dont want to spend to much more on my car :P if possible.....
Now i am thinking of going one of hypergears turbos, either the ATR43G3 or ATR43ss
I would like 300rwkw on the stock manifolds, and would like to use a dual stage for street use of around a bar, or whatever gets 250rwkw.
My question is what turbo? the more power (around 300) on lower boost would be more reliable?
if so i would be better off to go a ATR43G3? has anyone had any actual experience with these?
Would be nice to just be able to bolt it on, same water lines, comes with oil feed and spacer plate. also exhaust bolts straight up to standard for $1480 shipped
My supporting mods include Haltech e11v2, bosch 044 and surge tank, full 3" decent clutch etc.
Also what injectors?
i know 550cc will get you 300rwkw but as it is my daily i want the best fuel economy i can get,
my tuner said he tuned an rb25 with simmens 600cc injectors (i think ) and it was getting crap fuel econ. He put in ID 1000ccs and got 2km per litre better economy? 60 litre tank = 120km each tank more!
For you guys with around 550s and a 3076 size turbo what economy do you get?
or would i be better off spending 1k for ID 725cc injectors and a rail to suit for good fuel economy.
Any help much appreciated :)
Cheers, Chris.
  • Replies 158
Posted Images
I think the SS series of Hypgergear turbos are the best, their response is significantly better imo. For that power level I would choose the SS2. People have made 300rwkw using the SS2 on 98 fuel on around 20psi. I personally wouldnt choose the ATR43G3 on a standard rb25 as it doesnt have the best response.
Its not the injector size that gets you better fuel consumption but the spray pattern I believe. If its not a neo then you can use nismo 740cc injectors which are very popular.
First of all , make your mind up whether you want 300rwk or 250rwk , don't waste your time with changing boost pressure , you can do that with your foot (if the haltech can , drop your rev limiter down if you don't trust yourself) , second , the way my tuner explained injectors to me is vaguely : for fuel economy and better tune spend the $$ on decent proven injectors with a good spray pattern , they will pay for themselves in the amount of fuel they save compared to buying bad quality ones :)
I have a Garrett GTX3071 on my standard manifold and have 850cc Power enterprise injectors making 288rwkw on bout 21psi and i get bout 450km out of a tank of juice but my car isnt a daily drive so when i get in it i generally head for the hills for some spirited driving :nyaanyaa:
My last tune when my nistune was installed with the standard turbo made 203kw on 12psi and my fuel economy was almost 100km worse on a tank of juice than it is now with 85kw less!:blink: So i guess the tune has alot to do with fuel economy also mate :thumbsup:
Cheers, Chris.
So what sort of spray pattern should an injector have to return good fuel economy??? Can someone explain? I was thinking of getting siemens deka 60lb top feed high impedence (EV1)injectors for my R34 NEO from ebay $279 for the lot which is darn cheap! What sort of spray pattern do these have and are they 'inefficient (fuel economy wise) injectors' seeing as they are cheap??pinch.gif
Thanks heaps for the replies :)
Well i may as well go for 300rwkw, he has just dynod a turbo that made 325rwkw on 20psi I think, and 200rpm response better than the g3 I'll look into it a bit more...
Mick_o, that's good! That's more than my car gets now standard haha, what kind of response do you get with the gtx3071? standard motor? What about inlet manifold?
What would be the most pressure you can run with the standard motor/inlet manifold? Think my tuner said he has had to put a fair bit more fuel in certain cylinders with the standard inlet manifold above 19psi.
The guy from hypertech dosent use an adj. Exhaust cam gear either so maybe I cam get a little better spool rate there :)
May as well get the id725 cc injectors, more room to grow anyways and apparently really good on fuel.
Thanks heaps for the great replies, keep em coming :P
Also Harey, the ss2 does look good :)
If you have a look at the rb25 dyno threads he put the new turbos dyno sheet up there, it looks like a good compromise between the two.
What kind of response have you seen between the two?
And yeah the Id injectors are supposed to have a very good spray pattern,
+1 for the 2835 pro s, mine is running 280kw @18psi and very responsive (with other supporting mods such as cam gears etc)
With nismo 555 injectors and a tune ever so slightly on the rich side I'm still getting around 430-450 k's out of a tank.
FWIW ~280kw makes for a dam fast street car especially a well setup gtst
I was surprised by my fuel economy but my car was tuned by yavus at unigroup and hes the go to man! Lol my motor is completly stock other than the go fast bits i see full boost in 2nd gear bout 3800-4000 3rd gear is prob 3500ish ive had near 27psi into my car few times briefly with no probs! Im thinking bout scrapping the nistune for a link G4 ecu and an E85 tune and 25psi + boost real soon :-)
................r it all started to add up price super quick. Have realised i dont want to spend to much more on my car :P if possible.....
While the HKS 2835 is a GREAT turbo it's not exactly cheap. If it was even remotely cheap I'd have one myself.
I woulda been waving that flag too but it didnt exist when i was in the market for a turbo :-( still happy with the garrett response probably isnt as good but when its on it still kicks ya up the ass! Haha
This is very true, one big bonus is you get everything needed to make it a true bolt on.
But I do agree you are paying extra for the hks tag, but you forget about it when you push down the right foot :)
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
