  • Replies 231
to run a 10 in a full weight gtst, you will need good tyres, try aim for something better then ET street radials because they wont cut it, about 375rwkw, a good clutch and also a decent launch control and ecu with a tuner who can sit with you at the track and play with boost control trim on gears, boost control trim on wheel spin, and ignition timing retard on wheelspin, and also the launch control must not spool too much boost off the mark.
you need a 1.6 or lower 60 foot before you will grab it also.
Its not easy to do on a full weight street car, but i never gave up until i cracked it, i ran 10.80 @ 135mph before i gave up.
if you want to run the 10 you need to put in some hard work!
Except it hasn't done a 10 yet :P
I differ in opinion to most people who want to run 10s
A single 10.9999999 is different to a car setup to run half a dozen in a row. That is where car setup is important
I also don't like to see people wanting a 10 sec streeter but not want to drag "race" ie something other than a off street Wednesday night
I understand not everyone wants to cage their car....
If you don't, set it up to run consistent low 11's and hit the track as much as you like
That's gotta be one* of the dumber things you've posted.
*aside from the 2JZ/Supra talk on a RB/Skyline based forum
If someone wants a street car, on DOT radials that can run a 10.
And drive it around daily, for a reasonable budget - who cares about a "real" comp.
LOL I agree with that one, that Zebra seriously needs to go back to the zoo! ..Saying after reading some of his posts..>_<
ahhh you guys are f**king retarded >_<
you guys want to spend 11ty $$$$ on getting a car to run a 10...ONCE..because you will be booted...then what....spend more money on changing it to a circuit car
Silly me for thinking people who want a "10 second car" actually want to run 10's more than once.
Its like buying a V8 Commodore.... Its no special supercar out of the factory, not unless you buy something really expensive..
But hey if you want a V8 taxi then thats good for you. On the same token if somebody wants a 10 second skyline for the sake of saying I have a 10 second skyline then good for them too LOL
Oh Noez!!!!
God Forbid any variety on the internet....Don't tell me you snatched the rights to "Nissan Skyline" too so you can claim it as your own and make money of others hard work
i thought WSID was introducing the new rule cause heaps of owners of new Fords & holdens where complaining about putting cages in there brand new $80K cars..
most these cars can run 10's for under $5000 of mods..
Ive gone the easy way and have a C4 and 3800 stall. But dont have the 10 yet but shouldnt be far away :thumbsup:
Most people also don't realise how quick a 10 second car is. Fastest car i've ever been in was my dads R33 with 350rwkw, did a low-mid 11 @ 125mph which was freaking quick. Not saying this about OP, but a lot of guys go from a stock liner and think "oh i want a 10 second car hepa derpa" without knowing how quick it really is.
Nope, they did a backflip on the decision unfortunately
never happen on street tyres
drag radials as a minimum and you would be looking at 550+bhp at the crank to get you a high 10 at around 130mph after lots of practice
Auto or manual?
Lots of practice.... PFFT I did one pass :nyaanyaa: But I guess it wasn't a 10 :pirate:
In a manual, you would need atleast 400rwkw and MT Streets and know how to drive. Really drive.
I had 360rwkw (dyno dynamics) or 410rwkw (dynapac with correction) and yes knowing how to peddle well and smash gears helps
I don't think you need a lot of the things you have listed >_<
Also on the street a 10sec car isn't really a 10sec car... Unless it's a GTR :)
Edited by SimonR32
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
