  • Replies 231
to run a 10 in a full weight gtst, you will need good tyres, try aim for something better then ET street radials because they wont cut it, about 375rwkw, a good clutch and also a decent launch control and ecu with a tuner who can sit with you at the track and play with boost control trim on gears, boost control trim on wheel spin, and ignition timing retard on wheelspin, and also the launch control must not spool too much boost off the mark.
you need a 1.6 or lower 60 foot before you will grab it also.
Its not easy to do on a full weight street car, but i never gave up until i cracked it, i ran 10.80 @ 135mph before i gave up.
if you want to run the 10 you need to put in some hard work!
Except it hasn't done a 10 yet :P
I differ in opinion to most people who want to run 10s
A single 10.9999999 is different to a car setup to run half a dozen in a row. That is where car setup is important
I also don't like to see people wanting a 10 sec streeter but not want to drag "race" ie something other than a off street Wednesday night
I understand not everyone wants to cage their car....
If you don't, set it up to run consistent low 11's and hit the track as much as you like
That's gotta be one* of the dumber things you've posted.
*aside from the 2JZ/Supra talk on a RB/Skyline based forum
If someone wants a street car, on DOT radials that can run a 10.
And drive it around daily, for a reasonable budget - who cares about a "real" comp.
LOL I agree with that one, that Zebra seriously needs to go back to the zoo! ..Saying after reading some of his posts..>_<
ahhh you guys are f**king retarded >_<
you guys want to spend 11ty $$$$ on getting a car to run a 10...ONCE..because you will be booted...then what....spend more money on changing it to a circuit car
Silly me for thinking people who want a "10 second car" actually want to run 10's more than once.
Its like buying a V8 Commodore.... Its no special supercar out of the factory, not unless you buy something really expensive..
But hey if you want a V8 taxi then thats good for you. On the same token if somebody wants a 10 second skyline for the sake of saying I have a 10 second skyline then good for them too LOL
Oh Noez!!!!
God Forbid any variety on the internet....Don't tell me you snatched the rights to "Nissan Skyline" too so you can claim it as your own and make money of others hard work
i thought WSID was introducing the new rule cause heaps of owners of new Fords & holdens where complaining about putting cages in there brand new $80K cars..
most these cars can run 10's for under $5000 of mods..
Ive gone the easy way and have a C4 and 3800 stall. But dont have the 10 yet but shouldnt be far away :thumbsup:
Most people also don't realise how quick a 10 second car is. Fastest car i've ever been in was my dads R33 with 350rwkw, did a low-mid 11 @ 125mph which was freaking quick. Not saying this about OP, but a lot of guys go from a stock liner and think "oh i want a 10 second car hepa derpa" without knowing how quick it really is.
Nope, they did a backflip on the decision unfortunately
never happen on street tyres
drag radials as a minimum and you would be looking at 550+bhp at the crank to get you a high 10 at around 130mph after lots of practice
Auto or manual?
Lots of practice.... PFFT I did one pass :nyaanyaa: But I guess it wasn't a 10 :pirate:
In a manual, you would need atleast 400rwkw and MT Streets and know how to drive. Really drive.
I had 360rwkw (dyno dynamics) or 410rwkw (dynapac with correction) and yes knowing how to peddle well and smash gears helps
I don't think you need a lot of the things you have listed >_<
Also on the street a 10sec car isn't really a 10sec car... Unless it's a GTR :)
Edited by SimonR32
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
