Lolz at Simon, 'take your slow Gts-t and go home' hahaha that really cracked me up, how many awkw wast that T04Z GTR??, i think i dont like my GTT anymore...
430rwkw, that video it was only running about 400rwkw
It was a rocket man, why would you give that GTR up for a sideways sliding GTS-t....me no understand..
I sold my GTR for a deposit on my house. I bought my Gts-t for cheap after that and having been building it up since :cheers:
  • Replies 231
Sensible driving, unless you took off like a granny, 1st gear in a high powered gtst is useless as soon as it comes onto boost it's wheel spin and same with second. In the rain.... Omg you have absolutely no chance of getting near boost. The gtst is quick don't get me wrong, but when it comes onto boost say on the on ramp like you said from 60 or 80 you just wait to correct the steering wheel if it completely breaks traction or it's twitchy fighting for grip.
The gtr just has a feeling of immense power and torque and when you get on the go pedal hard or soft there is no worries about grip. You have to look ahead to see how far the car is ahead of you as it just picks up speed über quick.
The gtr is able to use its power on all of its range and gears without issues to be quick, the gtst is fast once you get past the looseness and wheel spin.
Yeah but it takes a massive amount of man essence to pilot that rwd GTST. A school girl could drive a GTR fast though.
I'm not denying that, that's why sometimes I would like to have a 300kw gtst cause there so much fun. The thing I'm learning about the gtr compared to the gtst but is how fast you pick up speed because there is no wheel spin, you have to be careful of how far cars are ahead of you before you bring it onto full boost.
Has anyone with a GTS25t or GTt with around 400kw tried them on MT ET street radials?? I've been in a 10s R33 and on street tyres it was definitely a joke below 4th, though seen vids of Supras in the states with mental power being relatively composed on radials more suited to the purpose
it's all in the setup...
i have had a 300rwkw gtst for around 3 years now with a fairly responsive setup, and for me it all comes down to tyres.
Usually i run Nitto NT-05's (only in a 235) and with them i can smash the firewall in any gear with no worries providing I keep it set on low boost (300rwkw). on full boost (325rwkw) it's a little beyond the possibilities of the rubber, but still very predictable.
but an R with the same power to weight and response will eat a gtst every time
But how much more power does a GTR need to compensate for the extra weight of the 4WD system.
My 300ish killer wasp T was keeping up with, and beating a few 300ish killerwasp Rs, needless to say they were not doing 8k launches, and last time I was at the drags a old VL was smashing everything with its old RWD system.
It's not as simple as "It's a GTR man"
Let's settle this at the next SAUNSW drag day, I'll race for icecreams and coffees, I'll be in my RWDFTW boat, I'll race any simular powered GTR on the day.
It's funny how people think GTR's somehow drive themselves around corners. They do bite if you get it wrong!
This... Is quite true.
While wrxs and evos can be piloted by any gumby, I've only been in one GTR on a track where the driver knew how to drive it.
Remember attessa (awd) doesn't come into effect on a GTR until the back comes loose...
So to be quick, you must get the back loose, point the front where you want to go and open the throttle... Most people back off at the point of the loose rear. Most GTRs only get there awd used on the launch for this reason...
Your in mark!
I'm I'll be running my 400ish rwkw tune though, that will even up our displacement difference ;)
quick rough maths says around 23% (assuming 1350kg gtst and 1750kg gtr)
so ~300rwkw gtst = ~370awkw gtr
You must be talking about the 35 GTR...
Must remember torque is goin to play a large role in this as well, it's not just all killerwasps
Not all the time. It's determined by steering angle, speed, RPM and throttle position. If you go back to 2nd or 3rd on the freeway and nail it for example, you will see the torque gauge rise and fall.
shit... sorry, you are correct... so assuming 1550kg for a 33
figure would be more like ~340awkw
makes a bit more sense ;)
also i'm not taking torque into account at all here... just power/weight
+1
Mine will do it even taking off mid-throttle from the lights. No chance there would be wheelspin, but it sends power up front regardless for quite a while longer than you'd think.
But then i do have a modded transfer case, wondering if that makes a difference or not as well.
+1
Mine does it too pulling away from lights. Might go to to 10kg/m for a second or two then back to zero.
I was neck and neck with an R35 GTR down the main straight of EC when I only had 320rwkw and im sure his wasnt standard.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
