Top bearing. Ignore the scratches on that photo. It's where we pused the piston and rod out.
Bottom bearing.
15 months (10,000 kms approx) of running E85 using 300V 15W-50 oil. Engine was alive for 32,000 kms and used the same oil the whole time. 8000 RPM generally was the shift point but it did see 9000 a few times. They don't look half bad considering the oil pump died and the head is as useless as tits on a bull.
Bottom bearing.
and didnt burn a drop of oil its entire life :worship:
I'd say that would have to do with the super tight clearances and the run in :thumbsup:. Spoke to Mik about the run in and it was long hard pulls in 3rd and 4th up to 6500 within 10 kms of being screwed together. He did that every night for a few weeks on Old Pac.
yeah for sure, was obviously bolted together nicely... stupid pumps :domokun:
Bottom bearing.
What happened to the head to make it useless ?
Oil pump smashed. Ex cam welded itself to a few cam caps, belt jumped a few teeth and every ex valve got a little frisky with pistons (bent every valve and scored the chambers) . Intake cam is ratto.
Fark...talk about a catastophic chain of events caused by one shit part ,hope it didnt damage the RRR block .
maybe the 15w50 was the key then. I know Midori built my 26 on 10w40 300V and i would think that is a standard weight/viscocity for a street R, and if there are indeed issues of thinning etc, perhaps the 15w50 covers that off and it's ok to run the 300V.
Be interesting to see what Motul themselves think after sending them this info.
I would still like to have a sample taken and sent away although after it went bang I wasn't really in the mood! I don't think the amount of metal (or should I say bits of oil pump gear) would give a good and accurate analysis. A susmmary saying "Too much oil pump shavings in oil. May need to check engine" wont tell us much pinch.gif
Maybe chemically the Ester base oil's with alcohol fuels dont mix but changed enough it doesn't become an issue. The longest mine ever went without an oil change was 2000 kms. Track days and dyno tuning it always got new oil.
And you said it wasn't using oil! Man, that's "using" oil. ;)
Does that mean an ester based oil is fine to use with an alcohol based fuel? (getting back on topic)
it's actually more time that's important than k's. if you take your car for a thrash, have a bunch of contamination sitting in the oil, it has time to react with the ester even if it's not being driven. obviously the more k's and the more blow by = more contamination, so it's a mixture of a few elements really. but yeh, from what penrite say, they believe that you will generally need to change oil for other reasons before the ester begins to break down, so with regular changes it is ok. i'm gonna aim to change every few months which will be about 4-6 track days, so should be fine.
with how you drive? what kinda oil temps are you seeing at the track?
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
