  • Replies 742
lol I probably have spent enough on the car over the years (engines at least) to be there.
It is a good chance to have a beer or 10 with people from all over the place.
Everytime you mention beer, I think slim dusty!
You entering Boxhead?
Probably not although would love to have a crack for the "atmosphere" of it all, kind of one of those events you put on your bucket list to do.
good to see though i kicked this thread back to life :) Bring on August!!!
Has the just jap 35 posted any quick times? I haven't heard of any although I think it's a pretty new car.
What Im wondering is-which car will he be driving? Will it be the Just Jap 35 that has raced already in Japan and has posted some quick times according to that article or will it be a different car built here? Havent heard anything about Just Jap building a car here.
umm Just Jap have had a race/rally R35 in the country for about 5 years....if it is still in tarmac rally spec it will be very speed challenged compared to the big $$$ r35s getting around, those regs allow very few changes.
it's definitely the ATTKD Just Jap R35 in Japan. relatively mildly modded to date with the HKS GT800 kit making plenty of power but little chassis mods though I am sure they will be prepping the car beyond what is noted in the articles after chatting with Steve.
It hasn't put any times down on R spec tyres yet as it has been running in the street radial class (not sure what exactly which tyre but it is a Hankook street tyre they have been using).
http://www.skylinesaustralia.com/forums/topic/385105-just-jap-racing-time-attack-r35/
umm Just Jap have had a race/rally R35 in the country for about 5 years....if it is still in tarmac rally spec it will be very speed challenged compared to the big $$ r35s getting around, those regs allow very few changes.
I forgot about that car but I was referring to them building a brand new car specifically for time attack.
Read back a few pages. Mark has his finger on the button with most of this stuff it seems.
Cyber EVO had, an EVO. However Cyber EVO are doing a R35, was meant to be 2013 though?!?!?
Whether they are calling it Cyber EVO (as in the team) or not Cyber GTR (with new model in the naming) i do not know.
Steve - If you know more - SPILL :cheers:
Whispering Jack hard!!!
Cyber GTR was suppose to get a full pamper treatment with its engine management. Unfortunately tilton has held them up with a gearbox. So no goer
My car is supposed to get tuned next month but my tuner is not available between 13th to 23rd ..... why? because ill be
in Japan replacing the Power FC and putting a full system in the Cyber EVO instead........ okkkkaaayyy .... coming to WTAC 2012 wooooot woooooot!!!!
:cheers:
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
