Turn 5 has also been changed due to the extra pit lane added to the outside of the curb meaning you can put all 4 wheels over the curb (which isn't a curb, just a concrete strip dividing the track from the pitlane).
The exit of Turn 9 is also much wider giving better exit speeds.
Laptimes will be easily a full second quicker than last year prior to any car development.
We find with the changes to 6 - 7 - we are slower up over the hill in the R33 and the AU, it hasn't changed our exit speed at 9 on data yet, but definitely less grass and dust entering vehcile.
The above surfboard splitter - would actually be legal to run in CAMs 2A closed sports cars bar width - must have some good front springs, if it gets up to 200kms it would have 4 tonne of downforce. He will need 20 ply front tyres
Cheers
Stuart
  • Replies 742
Nein- what sav man said.
From what I've heard/saw last year, its pretty much a Supertaxi chassis with the struts and stuff to make it eligible to compete. Plus a 4 speed!
Should sound great down the main straight, but not be an outright contender.
used slicks, best/cheapest way to get your shakedowns for mechanical gremlins out of the way prior to working on setup.
we won't be at WTAC, won't get it all finished on time I'm afraid.
Have opted to complete the build properly without crazy amounts of pressure and spend a good 10 months testing before the cyber GTR comes out.
should be a great event this year!
Ahhh damn was looking forward to seeing your car again!!
But respect that you want to do things 110% will be an absolute weapon once done
Pulse racing Evo will be having a shakedown at Wakefield at Evo nats this weekend looking strong this year
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
