that is a meaty looking power curve! What setup are you running again? 6boost high mount twin scroll with a gt3076 running dual wastegates wasnt it?
Did you up the boost or just leave it on 18psi?
Edited by Mitcho_7
How would you compare them to KU36 in terms of life and grip?
I have RSR at the moment and they have lasted almost 10,000kms but the grip was substantially reduced after ~5000km
I've not used a KU36, others i know have - and were not particularly impressed... However for the price, it was ok.
However the price has gone up recently, making them a not-so-good option now for thier price. If you have RS-R, i'd stay with them or go AD08
+1?
.....it's in 25 dyno results
Edited by WMDC35
Fuel economy, I get 500 to a tank no problem. Never run out , probably get even more if I pushed it.
One thing I will ask though:
How's your oil consumption with 300?, mine has increased to a litre every 2000km now!!! When I was on 250rwkw it was prettty much zero.
Edit: Forgot to say, I have a catchcan and its pretty much empty after +10,000km. Nil leaks either so its burning, but you can't smell it or see it.
And oil is Castrol Edge Sport 10w-60 fully synthetic.
Thats some frequent top ups for a car thats so good on fuel, even after hours on the dyno my oil level doesnt fall , gets very dark looking though, try some Mobil 1 instead...
is it possible the oil rings have broken?
Edited by SliverS2
I used to get 500 to a tank and used a litre every 1500-2000 with almost no visible smoke. Used 5 litres from Perth to gold coast(4450)
When pulling it down 5 ringlands were broken. Was like that for 90000. Was around 230kw.
LOL you deserve a medal for this. 5 Broken ring lands, drove it for 90 thou and from Perth to GC.
You Sir are Awesome.
It never died and I would have continued to drive it but I got a company car so decided to take it off the road for a while. Had 115-120psi compression
Oh and Per-GC and return, both ways non-stop apart from fuel. It loved it
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
