Finally leaving this group... Unfortunately not the way i wanted too lol
My stock NEO is finally tired, but it has copped a beating as a dedicated track car for the past 2 years so it was self inflicted!
Engine ran over 300kw, just shy of 400kw at times since 2011 and was daily driven up until 2015ish... Since then its been thrashed on track for more events than i can remember! Engine still runs and does everything as it should, its just pushing oil on track so time for a new build!
Stock NEO's FTW :cool:
  • Like 1
Me too :(
I have a new motor, it is unfortunately built lol
I blew (well Phil did) cylinders 1/5/6. Smashed a bunch of ring lands, filled the sump with metal, destroyed the head, and destroyed a fairly new turbo. Same as Matt, plenty of abuse and anti-lag launches LOL
56 minutes ago, Dose Pipe Sutututu said:
Me too :(
Lol you animal!
I pulled mine out before total destruction as i am building the original :P
40 minutes ago, 34GeeTeeTee said:
Lol you animal!
hahah well that motor was totes fuuarked, the bores were cooked the head was fuuarked too.. had engine bits and pieces holding some of the valves opened.
Had to buy another motor!
#neoforlyfe
  • Like 1
On 02/12/2017 at 8:10 AM, Stick180 said:
That was my thoughts, and at about $1200 AUD landed, its worth a shot.  Not sure on timing, but knowing my tuner it wouldnt be anything crazy. Because of the EWG spring drama, its not building boost like it should, and its dropping 2-3 psi upto. So once i have that sorted i think driveability will be much improved. When it is on boost, its very punchy and the spool noise is pure jizz
I just noticed your post and I'm keen to see more of your setup and results so far as I was looking at the S252SX-E for my RB20 with VTC as well. Do you have any more pics of the mods done to the housing ? Did you change the spring in the gate to improve the spool ?
#neoforlyfe
I am staying NEO... Just far from stock :D
RB20 with VCT? Talk to me about it haha. You using an RB20 Neo from a 34 or retrofitting VCT?
Nope i just retrofitted intake camshaft and pulley from an S1 RB25 on my RB20 (coming from a R32). I drilled and taped the camshaft cap to install some kind of banjo fitting through the cam cover in the cap , a solenoid and then back to the head through the cam cover again. The solenoid is operated via the nistune ECU. It looks sketchy but it's working and not leaking so far.
I'll give some pics for you if you're interested.
15 hours ago, NEO25T said:
Are you able to let us know the condition of the motor once its pulled down.
Would be interesting to know if a set of rings and bearings would freshen it up.
I wont be pulling it down, but can ask the question to see what condition it was in... I am going to say well worn though :laugh:
  • Like 1
Finally joining after almost eight years in the making!
Result: 318rwkw @ ~20psi, United E85
Full specs and dyno sheet here: https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/?do=findComment&comment=7866850
  • Like 1
Overall condition was pretty good mate! Nothing sinister really! Just tired!
  • Like 1
  • 4 months later...
I've just joined the club!
mods: RB25DET NEO, Hypergear OP6 .86 Exhaust housing, Splitfire coilpacks, 044 Fuel Pump (460 Walbro ready to go in), 1000cc xSpurts, Nistune, Garage 7 IPC, 38mm Turbosmart ultragate External (Off stock manifold), 3" exhaust, FMIC, Aeroflow fuel lines
fuel: E85
power: 330RwKW on 20Psi
oil: ULX110 10w40
useage: Weekender
lifespan: Only had it for a few weeks but it was tuned almost a year ago
failure: Nil
comments: Definitely want a garret and aftermarket manifold to increase boost response and some Tomei camshafts but other than that this is way too much power for a street R32 haha
fuel: E85
oil: ULX110 10w40
useage: Weekender
failure: Nil
You could just swap the op6 housing for a 21u housing, will be all in full boost at around 3500rpm and only lose 15-20kw. Another option, upgrade the bearings in the turbo to ceramic ball bearing. Both of these options will be relatively cheap and make a reasonable improvement.
Otherwise a gtx3076 gen2 on a 6 boost will sound tits. Wouldn't bother with the cams, not required.
On 6/16/2018 at 3:19 PM, GTSBoy said:
Well, poncams are generally crap.  And they will NOT give you the response increase you're looking for.  Just the opposite, in fact.
Ah i thought tomei was well received with RB stuff, knew they were unpopular with toyota because they snapped a lot.
Also found out my turbo is actually an ATR43SS2 .82
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
