no adapters for that price, i got there fuel rail, its a chrome one $130 , needs a hole sealed up like ART's rail did.
Havnt got a reg yet, thinking about a Sard reg or if i can reuse the factory one that would save some $$$$
if theres some fittings i can use to adapt it then ill do that, stock pressure is enough for the 1000cc injectors , and yes will get a guage,
would rather put the money toward a pump rather than a fancy reg i dont really need. :yes:
Yes stock regs work perfectly except when running an aftermarket rail which doesnt allow the stock reg to fit
  • 1 month later...
ID1000's come matched for flow.... why is this important? check the pic below.
the pic attached is of generic ID1000 (bosch 1000cc) wanna bees. Look at the hug difference in flow.... there is enough difference in these to lose a motor... apparently it is now a big issue with all the 1000 and 2000cc stuff.
If your serious buy the matched ID's or at least get your 1000cc injectors flow checked.
I should add the injectors we tested above are NOT from our recommended supplier TUFFCARPARTS, we source our injectors from tuffcarparts.com.au (like the id1000s in my own car) and we are yet to have any problems.
The dodgy injectors are from another injector supplier.
  • 3 months later...
Sorry bout the old thread revival, I bought some xspurt 1000's , do I need to use the black rubber cushions off the bottom of the standard rb26 injectors or are the orings supplied with the xspurts ok?
Never mind, I answered my own question,
You talked about these ASNU1000cc injectors i like their 7 spray 30degree nozzle but im wondering if anyone has worked on these and if they are any different from the ID1000s. Also are these plugs and plug and play because i noticed they give different o ring size from 11mm to 15mm.
Im going to be fitting these on a R34GTT and will be looking at upgrading to dual fuel. Could anyone gimme some input on these and what tuners think about these.
http://www.asnuperformance.com.au/gallery/High%2BPerformance%2BInjectors/ansu-performance-1000cc-injector/110282
  • 3 years later...
rather than starting a new thread, I'm looking at getting id1300 for e85 application, it will be fitted to hks fuel rail, I read the plug on injectors are different (uscar?) and requires an adapter
I'm looking for the adapter that had a stock neat look rather wires splayed (as per attached)
suggestions...
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
