My LMGT4 are +30 front & +38 rear too.
During accident repair I had them roll the rears, but there's plenty of room there with 255's even without - I just figured 'what the hell'. However, even with 225 on the front I get some scrubbing - particularly on full lock, turning in driveways, etc.
My car isn't super-low but I've been pondering raising the front to try and reduce the scrubbing some. I would imagine it would be worse with 235, but I guess you can always try it out. It will depend how low it is, obviously.
Same wheels! Nice!
Hmm, well you see I have 235's on the front atm. But that's with the stock wheels. Still, fairly wide for a 7.5" rim. I never have any issues with them. My car isn't low at all really. Tein Super Street springs, only dropped the car about an inch.
This might be a trial and error process after all :P
Ok got tyres fitted up yesterday. Ended up with 235/40/18 at the front and 265/35/18 at the rear. Absolute perfect fit in my opinion. Wheels fit in perfectly with no scrubbing at all. I think it fills up the guards nicely.
What do we think?
Looks good, I recently just bought a set of silver LMGT 4's like yours too, same everything but 17", and will probably go the same width tyres as you :P
But my fronts get really dirty after one drive :|
Thanks for the kind words! I'll grab some more angles soon when the weather clears up (camera ran out of battery).
Feels great to drive indeed. You can feel the lightness in the wheels when you corner. Didn't really feel any difference in acceleration or response. More so in cornering response. There is slight increased road noise and a slight more harshness in the bumps (but you can't feel any more bumps than I did before, just the ones I did feel, are a bit sharper). But I guess that's a given going to a lower profile tyre. Overall though I love them!
Edited by Shoujiki
Hi guys, I'm new here and I've recently have gotten myself gotten new wheels for my r34 25gt, 18x8.5+20 in the front and 18x9.5+30 at the rear. The rear sticks out about an inch or less out of the guards, I was wondering if there was a way I could make it stick out less, or are they just too wide?
Edited by tny
My bad, wheels are 18x8.5 + 30 and 18x9.5 + 20
knew you had to have made a mistake. i used to have 9.5 x 35 on my rears, they were PERFECT fitment flush with the guards. there's nothing you can do, the wheels are wheels and you can't lessen offset like that. only solution : get new wheels (again)
As above, you can't make them fit any better. Unless you widen your guards! Correct offset for 9.5" rim on the GTT is +38. Mine fit perfectly with no scrub and fills out to the guard line. Your's being +20 means they will sit 18mm further OUT of the guard line. Which as you say, about an inch! Need different wheels is what it comes down to.
  • 1 month later...
I have a few question
im looking to put the varrstoen ES1 18x9.5 front +22 and 18x10.5 +22 for rear.
whats the highest offset you can use that will clear the front calipers?
I was thinking of going 234/40 in ft and 265/35 rears, will it be a big stretch on those tires?
will the rears rub at all?
will I have to roll the fenders?
Edited by US Frank
  • 1 month later...
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
