Test fitted some wheels.
F - 9 +30, 255
R - 10 +38, 295
With about 2.5 deg camber on the rear it was slightly pokey, and flush with 2 deg camber on the front.
Decided to go with,
F - 9 +35
R - 9.5 +38
RPF1s on their way from japan, hope this helps anyone looking to go big.
10588654_814795625218233_842044625_n1_zp
10585598_814803338550795_616279295_n_zps
  • 4 weeks later...
  • 3 weeks later...
I put on something similar Koya Cr Tek 18 x 8.5 +32 offset all round with Federal 595 235x 40x 18
Car is GTT r34.
Had the original wheela on it before handles excellent. No guard rolling.
  • 2 months later...
I want 18x9.5 inch all round, rears im fine with +38 but for the fronts its hard to find out exactly what offset i would need.
I would prefer no gaurd roll back can do if scraping.
Would +35 front be ok?
9.5 + 35 probably wont clear the inner suspension on the front.
You would probably need to go for a much lower offset if you want 9.5 on the front.
I went 18x9.5 +22, Volk Racing TE37SL's with 245/35/18 tyres.
Guards are rolled just to be safe and car is lowered w Coilovers.
Clears the plastic lining in the front with no rubbing at all.
Slightest poke on the front but hardly noticeable.
10834093_10153371011077571_1859539448_n_
10743558_10153312105092571_69778459_n_zp
  • Like 1
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
