On 27/08/2016 at 9:15 PM, YoshiFD3S said:
I have a '98 R34 GT-T.
I had some Rota Grid 18x9.5 +35 and 18x10.5 +35 with 235/40 tires.
Fitment looked good but the fronts actually scrubbed on the inside suspension when turning too far. The 235's on the 10.5's were also a bit TOO stretched for my taste.
So today I just installed some Work Emotion 11R 18x9.5 +20's all around and kept the 235/40 tires. The fitment looks perfectly flush with the rear fenders but sticks out considerably on the front. VERY aggressive but it DOES fit with stock fenders and doesn't scrub. I like it. I don't intend to roll. I'm running stock GT-R shocks/struts.
Pics:
C225EEB7-3802-4046-AD97-10790DA7A23C_zps
81050FCF-1B5C-40F3-94CB-92EF96C008E1_zps
97E5D908-5A53-46C5-A43C-5771137A6314_zps
mate i saw this in the for sale section, and seeing your in adelaide do yourself a favour and get your front and rear arches flared! If not you will last about 5mins before you get defected.
Or slightly flare the rear guards and sell the fronts and buy offsets that fit. Dont mean this to be a dick but being in Adelaide your not going to go long with them on without a defect
Thank you. I stand corrected as they have been scrubbing a bit, so I intend to roll and pull the guards a bit. Thanks again.
I got pulled over about 10mins after fitting mine and issued with a cautionary defect (9.5 +26)
The guy was pretty good about it after I'd explained I had literally just left the tyre place and was waiting to see what I needed to do to make the fronts fit
Unlucky, yes, but I couldn't really drive it hard without scrubbing anyway so I needed to do it
The rest of the car was checked and apart from a low hanging exhaust he let me off with a written caution
He said as long as nothing poked looking straight down over the front and rear guards I should be fine
I had to pull my front guards quite a bit to make it all fit flush. Given that one guard needed to be repaired I just heated them up with a heat gun and pulled them by hand and rolled the lips with a round piece of timber
Hi Guys,
I am planning to buy some 19" or 20" alloys for my skyline
It is a 1998 Gtt R34.
Looking at most websites, when you input the car details, it is returning 19" as max.
Do you know if fitting 20" is possible ?
if not, would 19"x 9.5 with 265 and 19x8.5-9 with 245 for front work ?
what are the issues with bigger wheels I should be aware of ?
I am getting a low offset ones(curved inside) . I guess clearence from suspension is important, not hitting fender and guards. what else?
does above impact handling ? Is wider alloy at back a good idea?
  • 1 month later...
Hey guys, ive been lurking this post for a while trying to find similar measurements and it seems like my fitment would work but i thought i might as well run it past you guys just to double check before purchasing.
So the measurements are as follows
front 18x8.5 + 30 Tyres 235/40
Rear 18x9.5 + 38 Tyres 265/35
I didnt want it to look too aggressive and poke so much. Just a flush snug look.
Any tips/help would be appreciated!
I'm no expert, but will help where I can.
Fronts will be fine, I run the same on mine and I'm happy with it.
Rears, i'm not too sure. Think 265 may be too big with 9.5. Someone else may be able to confirm on the rears.
If you're a stancebro, yeah 265 is too wide for a 9.5 lol.
Bronson, your specs are perfect, throw them on and enjoy. E.g.:
As per one of my early posts in this thread, I'm running 18x8.5" +30 on the front & 18x9.5" +38 on the rear, with LMGT4 -- same specs as what you're looking at.
I run 255/35R18 on the rears, and it's a good fit.  I looked into 265, but to my mind it's getting too far away from the factory rolling diameter, and would upset the speedo too much (though I believe it's still within legal limits, but it's been a few years since I checked the specs).
Good luck with your wheel choices :)
  • Like 1
Good luck with your wheel choices [emoji4]
That's the reassurance i wanted to hear ahah. Do you scrub at all? And do you mind sending snaps of the fitment?
At my ride height (a little - maybe 5mm - below minimum legal) there's a small amount of scrubbing on the front, at full lock, when going up steep driveways, etc. It's pretty minor, and it hasn't really bothered me.  When I had to get the car re-sprayed I did have them roll up the rear guard as a precaution (though it was entirely un-necessary). The front guards are untouched.
As I understand it in - at least in SA - you can go up to 26mm more wheel track legally.  With this wheel offset, there should be around 20mm wider track on the front and 4mm on the rear.  It's very much on the edge of pushing outside the guards, but I've had anal police officers look over it, and give it the go-ahead with no defects - but your mileage may vary.  I'm not running any crazy-excessive camber (I think a little over 1 degree front/rear) - with the standard approach of Whiteline adjustable camber kits front and rear (there's also Whiteline castor kit, subframe bushes, adjustable sway bars, etc).
Anyway, I hope that helps with decision-making.
That was insight full, i guess I'm safe. A little scrub here and there wouldn't hurt and if i want to avoid scrubing etc i can simply raise it. Thanks good man!
Ps: looking mint [emoji108]
  • 1 month later...
Been browsing through this thread too. lots of people close but not the same as the size and offset im looking at
CST Hyper Zero 1's in 18x9 +30 on a lowered R34 GTT Coupe.
Not concerned with stance or anything just dont want to have to modify the guards. and dont want to lose much turning lock (gf loves to apply full lock when in car parks etc)
What do you think? Appreciate any insights :)
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
