I'm looking at getting some Enkei RPF1s in SBC, going for a 18.85 +40 possibly for the front. Anyone know if this will fit okay or would I need to go closer to +30?
On 10/21/2018 at 8:55 PM, Gazzaa said:
Kinkstaah is right, the wheels will never fit but with stretched tyres you might be ok. You will need 235/30 for the front And likely 255/25 for the rear
i tried to get heroic and squeeze 275’s on the back but the passenger side has scrubbed away about 2mm of sidewall. With a +25 offset I’m gonn need to downsize to 265/35/18
I also adjusted the camber to negative 1.25 degrees
The wheels have 215/35 and 225/35 on them. I’m ok to roll fenders but if it’s gonna be sticking way too far out i’d rather not waste the money.
thanks for the advice guys. Maybe i’ll try and find 18x9.5 +22 and run staggered tires
7 minutes ago, kyl_er34 said:
If I were to go the 40, would it poke or something?
The higher the offset, the closer to the car. +40 will not fit as you will hit the suspension unless you are using a really skinny wheel. Try to stick between +25 and +35, width depending
That doesn’t sound right for a 10.5. I’m not saying it’s impossible but the tyres would be completely stretched to their limits, plus with such a low sidewall, its not the correct fitment for a r34.
i have. 235/40 stretched over a 9.5 wheel up front
the 10.5 will 100% poke out but with a stretched 255/35 or 245/40 you might be in luck
it mostly comes down to ride height and your suspension set up
this is how the 235/40 looks on the 9.5 (+20)
13 hours ago, niZmO_Man said:
As mentioned above, higher positive number = closer to strut.
Nismo sizes: 8.5" +35, 9.5 +38
Okay well that rules out the +40s. So hard to find the right size in this colour I want. Would I be able to fit a 10/10.5 on the rear of a R34?
Your idea of 'fit' is different to others (and different to mine, which is also different to others)
10 +38 is a relatively common size at the rear of the R34.
With a square setup, the rear of the R34 pokes more than the front does, which was a surprise to me when I put on a square set of rims, or at least it did on my own car.
Like all things - What do you want to do with the car? This will determine what kind of fitment you really want. Talking 225 on 10's means I'm not the best person to advise as I am a more 265 at the front on a 9in rim kind of guy.
But making it fit is a question of maths and geometry really.
shit man, the coupe must be different to the sedan because im running 10.5 +25 on the rear and im about 7mm from touching the coilovers lol. +38 id have no chance.
i guess these things are best to just lie under the car with a tape measure
https://www.willtheyfit.com/index.php?width=265&aspect=35&diameter=18&wheelwidth=10&offset=38&width2=265&aspect2=35&wheel_size=18&wheel_width=10-5&offset2=25
According to this, it'd be 6.8mm closer to the suspension Strut.
Note, did say 10 +38, not 10.5 +38. I had a 9.5 +27 on the back so I obviously had much more room on both sides.
This is just my personal opinion but do not stretch your tires too much or else it makes the wheel look like hub caps.
As if that's the reason to not stretch like that!  How about driving on the sidewall?  Or loading the sidewall completely contrarily to how the engineer designed it to be loaded?  Or how about setting it up to be popped off the rim edge when you hit a rock?  Or completely defeating the point of rim protectors on the sidewall of the tyre?  Or ruining the dynamic performance of the tyre?
Edited by GTSBoy
Well yes, and all that too!
But my pet hate is “Stance nation” crazy camber. I just don’t get it.
16 hours ago, demiosdd said:
How about 18x9+40 245/40/18 all round
The offset is too low for the front I believe.
Use the website willtheyfit and put in your current setup, get the measurements, grab a tape measure and see the difference for yourself.
1 hour ago, demiosdd said:
Yeah I don’t know the setup atm I want to run 18x9s all round if I can with out the wheel sticking out
18x9 + 30 is what you’re after my friend
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
