Where to get genuine Nismo ones?
I have the same setup as Terry on my Nismo LMG3's except I run the longer Nismo lug nuts. I got mine through Nissan Race Shop in the US because at the time the Australian dollar was really strong and they had them on sale so it worked out cheaper then anywhere I could find in the Japan but as you know the dollar is weaker these days (still half decent) so it might pay to check RHDjapan or Nengun first. Currently on the Nissan Race Shop website the Nismo long lug nuts go for around $150USD and the shorter ones $145USD with the valve stem caps being $35USD. Hope that helps
[edit]In regards to the Nismo lug nuts I also did see somewhere not to use a rattle gun on them. I refuse to and whenever I take my car to a shop where the tires have to come off I inform them as well and so far they have been good and not used a rattle gun on them.
Edited by Triptych
  • 4 years later...
Bump for this thread. Ive had cheap wheel nuts for quite a few days but now they are not holding up to track days.
What would ppl recommend for track days ? I want strength and reliable
thanks
On ‎1‎/‎03‎/‎2013 at 6:15 AM, JimmyRickard said:
What's the best option for a track only car? Can the genuine Rays nuts strip when using a rattle gun as well?
Best option is to not use aluminium nuts or a rattle gun without a torque bar.
http://www.kctools.com.au/Products/impact-sockets/1-2-drive-torsion-bars/1-2-quot-drive-torsion-bar-2
You can find steel nuts, my recommendation is avoid the open ended ones.  Water will pool in them followed by lovely orange streaks of rust.  I got some ARK design ones ages ago.  They are longer (50mm) to suit the longer Nismo studs.  Cant remember from where maybe ebay maybe direct.
http://www.arkdesign.co.jp/accessory.htm
6 minutes ago, vxsr33 said:
These are good, only problem is that the paint flakes off extremely easily on them.
I have no experience with them, just saw them whilst i was browsing one day
i dont use alloy/alu nuts because ive had multiple sets destroyed... when I learned my lesson and they were still getting damaged it was the different workshops who worked on the cars. Both my cars run Nismo steel nuts, havent had any problems with them. Bit of copper grease and theyve been good for years.
As far as coloured ones, im not sure, sorry.
  • Like 1
  • 4 weeks later...
326 Power lugs are super sweet.
Aluminum though so can be stripped if your not careful.
caps are interchangeable and come different styles and even spikes if your into that kinda thing.
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
