hey every one i was just wondering when the next show and shine will be on and where its gunna be,
havent been to one yet and i wana get some really good ideas for my car so fingers crossed their will be one soon.thanks.gif
https://www.sau.com.au/forums/topic/392519-show-and-shine/
There is a Show N Shine with SAU representatives at the ARC Forum Battle at Calder in about 2 weeks.
Otherwise the annual SAU Show N Shine is usually held at the end of the year :thumbsup:
This!
Or join up JDMST as well and they have a monthly meet up / show and shines.
SAU members are on there as well.
https://www.sau.com.au/forums/topic/392519-show-and-shine/#findComment-6244907
lol :D
Also SAU Nationals. Biggest gathering of Skylines (and other cars) in AUS far as I'm aware.
2012s will be even larger given QLD will be coming along in big numbers :)
Fingers crossed the 32 is ready in time.
https://www.sau.com.au/forums/topic/392519-show-and-shine/#findComment-6245178
Next SAU VIC meet is a Garage Cafe on the 21st of March.
Forum Battle will have some of best on show.
SAU NATS will have the largest example of the best of show.
Sounds like a good place to have a SAU VIC Meet.
https://www.sau.com.au/forums/topic/392519-show-and-shine/#findComment-6245675
lol :D
Your kidding right? Sau Nats is nowhere near the largest gathering of cars.. Of skylines yes but there is plenty of car things that get huge turn outs
https://www.sau.com.au/forums/topic/392519-show-and-shine/#findComment-6246640
Well the first half of your reply is pointless, as that's not why my englese clearly said.
https://www.sau.com.au/forums/topic/392519-show-and-shine/#findComment-6246687
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
